Which Layback License Plate for Detachable Tourpack
31-4076 V-Twin Layback License Plate Kit (1999-up FLT-FLHT)
15669 Custom Chrome Angled License & Rear Fender Brace Assembly $133.49
15667 Custom Chrome Angled license mounting plate only $50.99
Note: The original Equipment fender brace is longer than what is in the Custom Chrome kits. When the Angled license mounting plate is installed on the stock brace, the plate extends further to the rear and larger license plates may contact the taillight.
970-619 J&P Cycles Laydown Licence Bracket for 1993-2006 FL $117.99
Note: Appears to be the same as the 15669 Custom Chrome
970-181 J&P Cycles Auto Gem Laydown license plate bracket $69.99
Note: This product allows you to relocate your license plate below your taillight and have the option to retain your stock turn signal mounting bracket. Fits models: 1991-2006 FLT, FLHT, FLHR, 1978-84 FLH and 1986-2006 FLST (except FLSTS/FLSTF) (Lighted Jewels Not Included). Made in the USA by Auto Gem. Note: To retain stock turn signal mounting bracket, you will need to elongate mounting holes by 1/8".
2130-08 Drag Specialties 97-05 FLT, FLH 3-hole FL frame adapter $44.95
[IMG]local://upfiles/296/F79A57BAAF6F4CF692D8783F21B31942.jpg[/IMG]
[IMG]local://upfiles/296/B78A3A1661524B7D96631C22C78D798E.jpg[/IMG]
RE: Which Layback License Plate for Detachable Tourpack
Bill,
I have the layback LP mount, but it still makes contact with my detacheable tour-pak mount. How much clearance are you getting? I ended up having to put a rubber strip on the TP mount to keep it from rubbing against the Layback LP mount.
Kahuna
Kahuna
ORIGINAL: billnourse
I just used the one from HD. It worked as advertised, and had enought clearance for the torupac.
Regards,
Bill
Regards,
Bill
ORIGINAL: Kahuna
Bill,
Kahuna
Bill,
Kahuna
Regards,
Bill
Regards,
Bill
ORIGINAL: gsparesa
jek3fl
10-31-2011 06:03 PM
