Rear shock air pressure
#111
EG Ultra Shocks???
OK so this might be a stupid question but here it goes anyway. The other day when I had my bags off cleaning my bike I decided to check the pressure in my shocks. I took out my trusty pressure gauge and nothing... So I took out my second trusty pressure gauge and nothing. So what do you check the pressure in these shocks with and what should the pressure be? How do you fill them if needed?
#114
Get the Harley hand pump and keep it in one of your bags.
The HD pump has a gauge on it so you can also just use it to check the pressure like you would use a tire pressure gauge.
I keep mine with about 25lbs air pressure and it seems fine for solo and 2 up riding.
#117
#118
#120
I run 50 psi all the time. 10 Ultra and fully loaded touring. Even when it's unloaded I leave them at 50. I'm 220 and it has bottomed out once or twice.
Given my weight and the loaded gear the owner's manual shows 50 psi.
08 and earlier max=40psi. 09 up max 50psi.
