Rear shock air pressure
#141
#143
Air Shock Pressure
My Electra Glide was riding like a log wagon. Being new to Harley, I read the manual and it said to use hand pump and keep it at 10 psi solo if over 200 lbs. Being 245, I did this. After reading this forum, I just raised it to 20 psi. Wow!! Amazing difference. Thanks guys!
#144
On the ride home when I purchased my used 08 Ultra I hit a manhole cover that was raised a little, I thought nothing of it as I was approaching it, whamm. That back end hit and I my back was feeling it for blocks. I bought a shock pump instantly for the dealer and found I had zero pounds. I put 15 psi in and the ride was incredibly better, Like a different bike. I've been monitoring the pressure now for months, it's been holding steady. I even tried putting a little more in, 20 psi, but could not feel a difference. I've been riding with the 20 psi and it seems just fine solo or 2 up.
#146
With reading this thread i gather to use a H.D pump to add air... along with the 10 percent rule for PSI
My question is i tried to let the air out and nothing !! Does this require a H.D pump as well to release air ? I thought it be like any other valve once depressed the air would come out
Not the case ...so how do you let air out
#149
I'm 205 with wife at 130. We run 40lbs and occasionally bottom out. I have to check pressure frequently. it will bleed off every 3 weeks or so down to 25lbs and I really bottom out with that pressure. My old bike an 07 we could run 30lb and be ok. You must have a pump to keep your pressure steady.
