Satellite radio hook up
Old 05-06-2009, 07:41 AM
Heath's Avatar
Heath
Heath is offline
Former Sponsor
Default Satellite radio hook up
Just went and bought me a new Streetglide, pick it up on Friday. Very excited!!
I have satellite radio in my truck and I have an extra mount but need different wiring I assume to put on the bike. Do they sell such kits?
Old 05-06-2009, 08:07 AM
rodnock's Avatar
rodnock
rodnock is offline
Yes, you can get a spare antenna and a cigarette lighter adapter at any Radio Shack. If your SG doesn't have a cig lighter you can get a kit to wire one into your fuse block.
Old 05-08-2009, 06:28 PM
Heath's Avatar
Heath
Heath is offline
Former Sponsor
Question about the antenna. The one I have is just a round magnet made to slap on the roof of a car. Is this the same one being used on the bikes? If so, where are you mounting it. Right now I have it on the steering column behind the headlight. It was raining today so didn't have a chance to test its reception but I'm guessing it's not going to be good.
Are there other antenna and where did you install it?
thanks
Old 05-08-2009, 06:49 PM
Trock's Avatar
Trock
Trock is offline
thanks
Heath, the antenna is the same. You can mount it anywhere it gets a good view of the sat without being blocked by your body or anything else. Some put it on the headlight or the handlebar area. Hope this helps
Old 05-08-2009, 06:55 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
I put mine on top of the radio inside the fairing....
Been raining for ten days here, so I can't comment on reception but lets put it this way, I can listen to the satellite radio inside my garage with clear reception, so outside should be the same or better.
If you don't want to pull your fairing apart, I have a new mini antenna (1"x1 1/4"x1/2") that I'll sell cheap....It fits great on the rear fender and gets excellent reception...
db2753's Avatar
db2753
db2753 is offline
Here are a few links, i got mine from TSS Radio. The Professional Motorcycle Mounts comes with a nifty pad for the antenna.
http://www.tss-radio.com/sirius-for-...les-c-387.html
http://www.myradiostore.com/sirius/s...rmoinkits.html
http://www.cyclegadgets.com/Products/?cat=SATRAD
Old 05-08-2009, 07:10 PM
Maxcustody's Avatar
Maxcustody
Maxcustody is offline
I have heard of some mounting it inside the fairing.
Old 05-08-2009, 07:16 PM
D2R's Avatar
D2R
D2R is offline
Heath, Try here www.tss-radio.com. You didn't say Xm or Sirius but I picked up the antenna with the short coax and the antenna mounting bracket and the 5 volt power supply. For the radio mount try www.leadermotorcycle. The mount works real well with my Sportster 5 radio which I move around to 2 other vehicles. Its machined out of aluminum and looks good.I plug mine into the audio input jack,sounds great especially with an Arc amp and speakers
Old 05-08-2009, 07:26 PM
HDUltraRider's Avatar
HDUltraRider
HDUltraRider is offline
IS it a Sirius or XM radio take a look at this for Sirius radio's.
http://shop.techncyclegear.com/produ...&productId=147
Notch2005
Audio Systems
12-15-2013 04:31 PM
FlatBlackGlide
06-01-2011 07:43 PM
whocares
03-30-2010 12:43 PM
rhinoevans
06-20-2007 10:14 PM
jeffca
01-11-2007 05:26 PM
Quick Reply: Satellite radio hook up
