removing upper fairing on my ultra
Old 05-14-2009, 12:07 PM
scottmiller's Avatar
scottmiller
scottmiller is offline
Stage III
Default removing upper fairing on my ultra
I am stuck...got all the screws I can see out.. removed the headlight bezel.. something is holding onto the bottom.. and I do not want to pull too hard.. Am I missing an attachment to remove here
Old 05-14-2009, 12:10 PM
Lt James's Avatar
Lt James
Lt James is offline
You're probably missing the ones down by the front forks, accessed by turning the bars to lock on each side and reaching in with an extension. Wish I could snap a pic for you but it's supposed to rain today and I took the cage into work.
Old 05-14-2009, 12:12 PM
jdreed520's Avatar
jdreed520
jdreed520 is offline
Yea that is it ...you missed the 2 that go in through the bottom between the forks. Like was said turn your handle bars to full lock and then look in the side with the biggest gap and the bolt goes through the chrome fork cover under the fairing..one on each side..
Old 05-14-2009, 12:14 PM
scj's Avatar
scj
scj is offline
You do not need to remove the headlight bezel.
3 across the windshield, two in between forks (one on each side. You will need to move the bars side to side to get to the screws) and the two from the inner fairing side.
Old 05-14-2009, 12:18 PM
MassHD's Avatar
MassHD
MassHD is offline
No just reach around and un plug the headlight.
Old 05-14-2009, 12:25 PM
Lt James's Avatar
Lt James
Lt James is offline
Oh, and buy the shop manual for the bike, it will be a priceless companion when you want to do any work on your scoot, best $50 (or so) you'll spend.
Old 05-14-2009, 12:34 PM
dawg's Avatar
dawg
dawg is offline
Received 2,955 Likes on 1,711 Posts
batwing removal with pictures HERE
Old 05-14-2009, 12:40 PM
Our07Ultra's Avatar
Our07Ultra
Our07Ultra is offline
It appears the center bottom fasteners are your problem. Hope this helps
Old 05-14-2009, 12:43 PM
Lt James's Avatar
Lt James
Lt James is offline
Thanks as always Dawg, I couldn't find that post !
rdam's Avatar
rdam
rdam is offline
Very nice. I bookmarked it. Thanks
Quick Reply: removing upper fairing on my ultra
