Oil Temperature
Old 05-24-2009, 12:10 PM
bigbg006's Avatar
bigbg006
bigbg006 is offline
Default Oil Temperature
I have an 08 Ultra Classic that I just put a oil temperature gauge. Can anyone tell me what the proper operating temperature should be. Thanks
Old 05-24-2009, 12:14 PM
Milan's Avatar
Milan
Milan is offline
185F to 230F should be about right. Gets any hotter than that I would consider getting a oil cooler.
Milan
Old 05-24-2009, 12:23 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
Milan
Amazing, you just happen to sell oil coolers to don't you?
Old 05-24-2009, 12:34 PM
Milan's Avatar
Milan
Milan is offline
Sorry, if you look at my web site you wont find any coolers for sale. Maybe you should look before you speak.
Milan
Old 05-24-2009, 12:40 PM
oldhippie's Avatar
oldhippie
oldhippie is offline
Default 230'F is normal crusing.
Normal operating temperature, when the bike is stock and fully up to temperture is approximately 230'F, when crusing along doing normal crusing. It'll be more or less depending upon your riding style, the ambient temperature, the speed your going.. all that stuff.
Many of the newer HD's run very hot. The expecially heat up rapidly way above that 230 mark when stopped in traffic. You can turn on heat management in the ECM so that the rear cylinder shuts down at idle, at high temps. I would guess this would help a lot.
I have an 07, did the Stage 1 upgrade with a PCIII and also put ona Jagg oil cooler. I never see anythign about 225 anymore. Runs great!
Old 05-24-2009, 12:47 PM
UALCapt's Avatar
UALCapt
UALCapt is offline
I concur with the temperature range stated above. I am a big fan of oil coolers. I flew large radial engine airplanes years ago. Temperature control (both cold and hot) is critical. An air cooled v-twin motorcycle engine is nothing more than a fraction of an aircraft radial engine and benefits from the same careful attention to temperature control ...this includes cylinder head temps as well as oil temps. My '09 FLHTP 103" has an oil cooler from the factory. Recently, I added Milan's oil cooler fans, and am pleased with the results. I have an oil temp gauge and can see the difference from the twin fans. "Anything" I can do to control the temperature of the engine is well worth the money and effort.
Old 05-24-2009, 05:54 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Milan
Oh, you don't sell the oil cooler itself, just the fan for it--thanks for the clarification.
Easiest way to cool off an '07 or newer bike is to richen the AFR just a bit since HD sets it sooooo lean for EPA compliance reasons.
Old 05-24-2009, 06:28 PM
armyof1's Avatar
armyof1
armyof1 is offline
can you set the afr by yourself, or is it something a shop has to do becaause i dont have a power commander?
Old 05-24-2009, 06:31 PM
mphamrick's Avatar
mphamrick
mphamrick is offline
I am going to look into the oil cooler, by HD. If that does not work then I am getting the fan.............
Old 05-24-2009, 07:12 PM
Milan's Avatar
Milan
Milan is offline
[quote=Harleypingman;5042659]Oh, you don't sell the oil cooler itself, just the fan for it--thanks for the clarification.
Again I apologise, I didnt realize that if you sell a product you are not allowed to voice a opinion. If you read my first post there was no mention of the product I sell. Nor did I say he needs to buy a oil cooler, only that if his temp gets above 230F that he consider it.
Milan
Quick Reply: Oil Temperature
