Reduced Reach Handlebar Install Questions. Cables? Wiring? Did they help you?
Thinking about putting the Reduces Reach handlebars on my 2005 Road King Classic. The stock bars kill my back. I've tried rotating them, adjusting grips, and so on. Time for new bars. Did these bars help you? Do the Reduced Reach Bars need different cables or wiring, Or will all my stock stuff work? THANKS!!
I don't know about the reduced reach bar's, but I put some Chubby Wild1 wo508's on my 2003 RKC,32.5" wide, 16" pull back 5.5" rise. I used all stock stuff but I lengthened my wires about 8 inches just to have lots to play with, the stock length probaly would have worked but it would have been very tight...I hope this helps
I just put the extended reach ( HD 2" Pullbacks ) on my '08 Ultra.
I did use the HD extended clutch cable and am glad I did as that would have been tight. The TBW cables were all plenty long enough, and the ABS brake line was more then long enough. I routed the TBW through the bars but not the rest of the wiring, just didn't feel like disassembling and reassembling the connectors. It took me a good 4 hours on the Ultra, but there is a ton of crap you have to remove ( basically the whole fairing ). And I was doing a deep clean as I pulled everything apart.
Now the bad news, my arms are at a much more comfortable position ( elbows slightly bent and relaxed ), but I am not real happy about my wrist position. I only put about 25 miles on the bike after it was done so I am going to give it another chance before I start looking for yet another set of bars!
Those who have the other brands, how neutral is your wrist position? Man I wish I had a nice set of buckhorns for the bike, lol.
No problems.
I ran the wires inside.
Took me a few hours.
yes I have an 84 vette....it has seen better days.
Not sure how your clutch cable is routed.....I did end up rerouting mine, no problems with it tho, and it's not tight at all, has plenty of slack.
I experienced the same concerns as Doombuggy posted in regards to the wrist angle, and also considered replacing the bars....but in a week or so I just got accustomed to the new wrist angle and end up very happy with the new handle bars.
The stock bars had a two piece top clamp, the new bars came with a one piece top clamp. (A one piece clamp should be used)
When disconnecting the wires inside the nacelle, I think one of the connectors was attached to the headlight bulb housing, if you remove it and don't reattach it, you can get the needed slack to eliminate the wire extension kit.
I made a good diagram of the wires in the connector before removing all the pins.
I was REAL glad I had a service manual when I changed the bars on my bike.
