?? new bars on '09 FLHR
Old 06-10-2009, 12:21 AM
onadraw's Avatar
onadraw
onadraw is offline
Default ?? new bars on '09 FLHR
I have a 2009 Road King FLHR. I have the heritage bars now and they are adjusted as far back as they can be. I need about another 2 inches 'cause I'm a short mfr.
I was considering the Wild 1, W0502 apes and also the W0508 RK bars.
I'd like your opinions on which of these bars will give the reach I need and also what extras I would need to do the installation.
I've heard that the W0508 would work without extended wiring, cable and brake line but I'm not sure if thats true.
Old 06-10-2009, 09:51 AM
onadraw's Avatar
onadraw
onadraw is offline
bump.
I've tried 3 different seats and decided I like the Mustang solo best. I'm reaching the ground ok. Not flat footed, but enough that I can move the bike around.
I can reach the bars that I have now but I would be more comfortable if they were about 2 inches closer.
Old 06-10-2009, 11:54 PM
onadraw's Avatar
onadraw
onadraw is offline
I can't even get a reply from Harley Goodies.
Old 06-11-2009, 01:15 AM
tslonige's Avatar
tslonige
tslonige is offline
khrome werks 300514. Sweepers the curve back towards the rider,
http://www.khromewerks.com/
Old 06-11-2009, 06:27 AM
keltonkrew's Avatar
keltonkrew
keltonkrew is offline
Now that's funny!
Old 06-11-2009, 06:55 AM
JonnyD's Avatar
JonnyD
JonnyD is offline
Jon here. man you know your gettin no respect when even he won't comment.....
About your bars, just how vertically challenged are you? I'm 5-7 and also have the mustang seat, but I did swap to the profile lowering shocks as well. I am running the RK chrome high bars and they fit very well and I can even pull em back more if I wanted too. They are pretty much in line with the forks and maybe even a bit forward.
They are an easy swap and require no cable/line changes. About $75~ for the version to fit the new throttle. Might be a good option for you if you didn't want to spend a lot of $$ and have it done in a few hours.
I sat on a bike with heritage bars and for me, the RK high bars are much better ergonomically. I have lots of pics of them on the bike if your interested.
FYI, if you did go with an ape, you'd need at least 12" or you'll be in the same boat your in now with having to pull em back. Believe me I sat on a RK with 12.5 Chubby's and they were borderline, 14's would be perfect. There not as tall as they sound. Good luck!
Old 06-11-2009, 08:11 AM
RK Ivan's Avatar
RK Ivan
RK Ivan is offline
I switched to the Wild1 518's on my '02 RK, there is alot more pull back from stock bars, they are a little on the beach bar side, but not anything like the beach bars on a RK Custom.
Old 06-11-2009, 09:56 AM
onadraw's Avatar
onadraw
onadraw is offline
Thanks guys. I'll look at those other options also.
LETSRYD
09-26-2015 05:12 AM
Henry89
03-22-2012 12:02 PM
PWFD
09-06-2010 05:00 AM
carlgrover
06-23-2009 01:18 PM
Certified Drunk
05-28-2009 11:40 PM
Quick Reply: ?? new bars on '09 FLHR
