Changing handlebar bushings-
Old 06-11-2009, 11:31 PM
Kbore's Avatar
Kbore
Kbore is offline
Default Changing handlebar bushings-
Do you have to remove the top of the triple tree to change the riser bushings on a road king? THe top ones look easy. THe bottome ones appear to require disassembly of the stearing head...
KB
Old 06-11-2009, 11:55 PM
OG1's Avatar
OG1
OG1 is offline
no just have to do one side at a time. crank the bars to the left to do the right side, then crank them to the right and do the left side.
Old 06-12-2009, 02:45 AM
TheBagger's Avatar
TheBagger
TheBagger is offline
Like OG1 said you just turn the bars fully one way and do one side at a time. There is enough room for the riser bolt to come out and then you can push the bottom bushing out from the top if it doesn't come out with the bolt.
Old 06-12-2009, 09:23 AM
Kbore's Avatar
Kbore
Kbore is offline
Doh. Couldn't see it- thanks!.
(saying to self: always turn the handlebars always turn the handlebars).
Old 06-12-2009, 09:39 AM
Beemervet's Avatar
Beemervet
Beemervet is offline
Why are you changing the bushings? If your bars are feeling a little loose, it could be because you have the two piece clamps. The one piece clamp is a great upgrade, especially for taller than stock bars.
Old 06-12-2009, 10:31 AM
tencrore's Avatar
tencrore
tencrore is offline
I just changed out my bars and changed to polyurethane bushings at the same time. This was on an 08 RoadKing... don't know if it applies to your model year, but the washers that came with the bushing kit were too thick. I know this probably does not apply to all aftermarket poly bushing kits out there, but just something to keep in mind.
What that means is that the riser will be a little too tall for the riser cover to bolt back on over the two piece nacelle. I was racking my brain as to why the nacelle and the riser cover would not line up properly. Luckily Livermore HD's techs know their stuff and that's how I found out about the washers. I had to dis-assemble it and replace the kit washers with the stock washers... I still used the kit poly bushings. That change in thickness made all the difference.
Hope this helps.
Old 06-13-2009, 01:40 AM
Kbore's Avatar
Kbore
Kbore is offline
WHen you go from a 5.5" stock hqandlebar rise to a 12.5" rise, the leverage is greatly increased. That leverage will increase the compression force on the bushings. COuld be a mistake, but I changed them out to match the compression of the rubber with the force due to the handlebar height (read quite a bit in the forum about the bushing and compression from taller HBs). Some people here have taken the stiffer bushings back out due to excess vibration so I am keeping the old ones, even though they loook pretty well squished up. I'm installing the one piece clamp as well.
Old 03-03-2012, 04:12 PM
Joker65's Avatar
Joker65
Joker65 is offline
GREAT answer..... Thanks!!
JT-FXDL
08-14-2013 03:10 PM
06Heritage
06-20-2010 09:25 PM
reissman
03-20-2010 05:08 AM
Harleypingman
02-20-2010 07:30 AM
BadPiggy
01-16-2010 03:03 PM
Quick Reply: Changing handlebar bushings-
