2004 FLHT leak
2004 FLHT leak
Has anyone had this problem, my 04 FLHT I replaced the factory inner primary with a chrome inner primary twice now. The first one leaked at the bottom bolt were the inner primary bolts onto the engine, now the second one is leaking in the same spot. Does anyone have any suggestions on how to fix this problem. I never had this issue before with the factory inner primary.
Ed
Ed
The bolts that bolt the inner primary to the engine (5 of them) on my 08 are these sealing bolts. I will have to double check as to if they are the same on the 04. Every time you remove them, you need to use new ones.
I know my 03 has lock tabs & bolts, I have repaced the rear seal twice and I noticed yesterday it is "weeping". Its not a full blown leak just enough to be wet. Have always been carefull to make sure not to damage the seals and o-ring during assembly. Kind of a PITA to keep opening up to change.
