Temperature readings from stock to Fullsac True duals w/XIED's
Old 07-03-2009, 06:18 PM
DrPlastic's Avatar
DrPlastic
DrPlastic is offline
Default Temperature comparisons between Stock to Fullsac True duals w/XIED's
Here is my unscientific temperature testing taken during my conversion to Fullsac True and XIED's
Some readings were hard to get a steady reading because the IR beam was reflecting off of the chrome and made for some wildly different readings! I tried to get the best reading I could.
Temperature readings taken during each stage of the conversion.
Temps taken with a Fluke infrared thermal temperature gauge
Idle / 2000 rpm
Head pipe readings taken at the oxygen sensor
Location........................ Stock.......... Stock w/XIED’s...... Full sac w/XIED’s
Front head..................... 220............. 230...................... 257
Front head pipe.............. 476............. 374...................... 460
Front heat shield............ 226 / 353..... 119 / 215.............. 136 / 251
Rear head..................... 193............. 225...................... 268
Rear head pipe.............. 362............. 407.......................562
Rear heat shield............ 147 / 155..... 107 / 134.............. 112 / 131
Left tail pipe.................122.............188.......... ..............268
Right tail pipe................139.............165........... .............255
Old 07-03-2009, 10:47 PM
DrPlastic's Avatar
DrPlastic
bump!
Old 07-04-2009, 12:42 AM
Arizona's Avatar
Arizona
Arizona is offline
Thanks for sharing. Looks like in some categories no big change over stock... Wouldn't have expected that.
Old 08-03-2015, 08:06 PM
Idahokid's Avatar
Idahokid
Idahokid is offline
You would think the fullsac conversion with the xied would have ran the coolest.Im thinking of true duals with the xied and wonder how it ran.
Old 08-03-2015, 08:14 PM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Really? 6 year old thread... My guess is; went very lean with fullsac pipe making more heat... xieds suck!
GroovusMagnus
2014-2023 Touring Models
02-06-2016 11:09 PM
"NO SHOW"
Exhaust System Topics
09-19-2012 07:40 PM
dohadex
06-17-2012 01:21 AM
lostrider06
06-24-2011 08:14 AM
harleyflo
09-12-2007 10:23 PM
Quick Reply: Temperature readings from stock to Fullsac True duals w/XIED's
