Rear Shock Air Pressure
If your connection(s) are good you shouldn't have to adjust your pressure except for ambient temperature changes. At the low pressure(s) the shocks are set at, that should mean only seasonally. First: you need to locate the leak(s). Get yourself a small spray bottle and fill it with about half a teaspoon of dish detergent. Then fill it with tap water. Most leaks in air lines are at the connections, so start there. Spray the connections with your solution. Any leaks will be easily identified by the bubbles. You can get the spray bottle at a Dollar Store; 6-8 onces is all you need.
If your leak is at a compression fitting, tightening the connection should solve your problem. If not, you will have to pull the connection apart. A small application of pipe dope on the male threads of the connection should solve the problem. Tighten your connection and you should be good-to-go. You can get the pipe dope at Home Depot or Lowes.
If your leak is at a tapered fitting, you may need to get some teflon tape. Make sure both end of teh connection are "clean". The apply several wraps of teflon tape over teh male threads of teh connection. Be sure to apply the tape in the opposite direction of the way you will screw the connection together. Otherwise, the tape will start to peel and you'll have another leak. Remember; gas fittings are "righty tighty, lefty lucy". You can get the teflon tape at Home Depot or Lowes.
Also check the Schrader valve(s); they do wear out and sometimes are defective. Make sure the valve is seated all the way and that the teflon ring (the colored piece above the threads) has no flaws. Make sure you use a Schrader tool and NOT needle-nose pliers. The Schrader tool is about a buck at any car parts store. Pliers typically bend the depression pin and cause leaks.
I hope this helps.
I hope this helps.
todya was the first time I used the HD air pump.. I wanted to see how much pressure was in the as soon as I turned the air pump on the air nipple it registered around 20lbs I pumped it up to around 28 or so becuause I am riding with a passenger...since I am around 150 and wife around 120.....I went to 28lbs....manual says around 30lbs for a weight of 300 lbs
