06 Ultra Fluid Capacities
Old 07-19-2009, 07:27 AM
gipsl67's Avatar
gipsl67
gipsl67 is offline
Default 06 Ultra Fluid Capacities
I just picked up an 06 Ultra and would like to change the fluids, but don't have a service manual yet. Can anyone help with the capacities, so I know how much to buy? It has the 88 cubic inch motor and 5 speed trans.
Thanks
Old 07-19-2009, 07:46 AM
SpiderPig's Avatar
SpiderPig
SpiderPig is offline
Default Fluids
Engine Oil capacity with a filter change 4 QT. (Check at 3 1/2) Drain Plug Torque 14-21 ft -lbs Black filter #63731-99 Chrome filter #63798-99
Transmission. 20-24oz Drain Plug Torque 14-21 ft-lbs
Primary 32oz Drain Plug Torque 36-60in -lbs
Old 07-19-2009, 07:47 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Uncle Scrooge is offline
Motor, 4 qts. Tranny, 22 oz. approx. Primary, 1 qt.
Old 07-19-2009, 07:52 AM
nocarb's Avatar
nocarb
nocarb is offline
Thanks
This is from memory for my 02. I could be a little off on primary and transmission.
Engine - 4 quarts.
Primary - 32-38 ounces.
Transmission - 21 -28 ounces.
You will need
4 quarts of oil, 1 or 2 quarts of primary fluid and 1 quart of transmission fluid.
You should also get o-rings for drain plugs, o-ring for trans. dipstick,gasket for derby cover and an oil filter.
Not to confuse you but if you use synthetic oil, most call for same oil in all 3. I use the same oil for primary and engine and 75W110 for trans on the 08.
Old 07-19-2009, 07:58 AM
Bigredone's Avatar
Bigredone
Bigredone is offline
Don't forget to pick up an O ring for the drain plug.
Old 07-19-2009, 08:31 AM
gipsl67's Avatar
gipsl67
gipsl67 is offline
Thanks everyone, that is what I needed.
Old 07-19-2009, 08:56 AM
loc's Avatar
loc
loc is offline
One of the best "pieces of $50 chrome" you will ever buy for you and your bike is a Service Manual.
BklynBound
Oil Archive (no new posts)
08-26-2022 06:27 PM
uer 84038
07-05-2021 04:09 AM
rich56
07-30-2019 11:44 PM
HoldFast71
07-27-2012 07:32 PM
jcbpa
05-10-2008 12:45 PM
Quick Reply: 06 Ultra Fluid Capacities
