Hydraulic Lifters
Old 07-24-2009, 01:36 PM
pmcburne's Avatar
pmcburne
pmcburne is offline
Default Hydraulic Lifters
What is the difference between standard lifters and screaming eagle lifters for the 96 cu. in. engine? Is there any advantage to using SE lifters?
Old 07-24-2009, 01:40 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
No first hand experience but from what I've read the SE's seem to have a higher failure rate. Most of the name builders seem to prefer the stock lifters. I run stockers in my 98" 10.5 comp motor and hit 6200 RPM regularly (every time I ride ) with no problems.
Rick
Old 07-24-2009, 01:46 PM
pmcburne's Avatar
pmcburne
pmcburne is offline
That's the kind of answer i like to hear. Thanks
Old 07-24-2009, 02:13 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
About $150. The service manager at my local HD store told me to use the stock OEM lifters and specifically recommended NOT using the SE lifters though I didn't ask for details.
Old 07-24-2009, 04:01 PM
xxxflhrci's Avatar
xxxflhrci
xxxflhrci is offline
I've also heard the of a higher failure rate for the SE ones.
FYI, in case you did not know, Twin Cams use the same lifter as a small block Chevy. I am running Crane #10530 lifters for a SBC. A call to Crane confirmed that the only difference in them and the ones with a HD part number is the price. Four lifters cost me about 50 bucks.
Here are some lifter pics for you to look at purely entertainment. One is of a comparison of the older HD A lifter and newer HD B lifter. The other is of a Crane 10530.
Attached Thumbnails Hydraulic Lifters-hd-5flifters2-1-.jpg   Hydraulic Lifters-crane-10530.jpg
Old 07-24-2009, 06:00 PM
pmcburne's Avatar
pmcburne
pmcburne is offline
Awesome. Many thanks
Old 07-24-2009, 06:18 PM
418S's Avatar
418S
418S is offline
FWIW. At high rpm hydraulic lifters can suffer what's called pump-up where the valve spring can't get the valve back to the valve seat fast enough. This can be catastrophic with valve-valve and valve to piston collisons.
The sollid lifters are just that - no hyraulic bleed to worry about. They're more high performance but limiting (re: RPM) due to the inertia of the lifter, rod, valve etc. (valve float).
Metrics get around the problem completely by using OHC - the rocker follows the cam directly - less inertial weight - higher RPM.
Old 08-02-2014, 10:04 AM
Igotwoxs's Avatar
Igotwoxs
Igotwoxs is offline
Stage III
Default S.E. vs Stock lifters
Just opinion but I'm currently repairing a friends 100hp Road King and he has installed stock lifters on his intakes and S.E. on his exhausts (why, I don't have a clue?) and the lifter that failed was the stock. This is just a FYI.
As far as stock vs. S.E. lifters in general the point that comes to mind is the higher failure rate of S.E. lifters probably has something to do with the fact that they're what's installed in high performance engines and the stresses are so much greater on them. It only stands to reason higher output engines tear up more parts. I figure it this way, the 300 lb. heads in engineering at HD don't arbitrarily slap a S.E. label on a product. My guess is they use higher grades of materials and quality control when it has the S.E. label applied. At least I like to think that they have our best interest in mind. If you just have to know, have the metallurgy tested on each one then let us know the properties of the steel and we'll all know.
Old 08-02-2014, 10:50 AM
cuda67bnl's Avatar
cuda67bnl
cuda67bnl is offline
never have understood how or why folks find 5 year old threads so they can bring them back up........
donhoe
Engine Mechanical Topics
02-22-2019 10:16 AM
skydude426
02-17-2017 08:16 AM
The Roadrunner
12-28-2011 09:29 AM
cthowards
02-11-2010 12:12 PM
parrothead306
Exhaust System Topics
03-17-2009 03:28 PM
Quick Reply: Hydraulic Lifters
