Garmin Zumo 660 Install
I'm leaving this afternoon for a 5 day trip to Yellowstone, Grand Tetons, and Jackson Hole. Waited 'til the last minute, but installed my Zumo 660 this morning.
I still have a few things to figure out, like playing the Zumo audio through the HD sound system, but I'll have 5 days to play with it and get it all figured out.
- used HD p/n 91843-97 supplemental power source, but kept the lighter socket for use on another project.
- used the RAM mount that comes with the Zumo for handlebar mount (it's very adjustable to get the right mounting and viewing angles)
- put spade connectors on the Zumo wiring harness and sealed with heat-shrink
- ran the wiring harness under the console (had to loosen the console and lift it to get the in-line fuse on the harness through)
- plugged the supplemental power source into the accessory power supply (right in front of the battery)
- plugged the spade connectors on the Zumo harness into the female ends of the supplemental power source
- a few wire ties to secure everything
Like htc said, I like the bigger, wider screen on the 660. Mine is not the HD version (didn't want to pay the extra hundred dollars). I found plenty of HD graphics to download to the unit to use as startup screen.
For the audio all you have to do is run a cable from the Zumo audio out jack, one of those three cables from the mount, to the Aux in on the front of the radio. Once it is connected simply change the radio mode to Aux and you should be good to go.
Turn the volume all the way up on the Zumo and use the radio volume to adjust volume.
Is your 660 the HD version or did you put the HD logo on yourself?
Yeah, but the 660 doesn't have XM. I need my XM. Does anybody know how I can run my XM and the 660 through my speakers. Could I splice the aux wires together? Would the 660's voice prompts trump the XM? Gotta make this work.
A couple days later I take off on the highway out of town, and the damn thing kept trying to get me to take these little side roads. I was cussing that thing ... almost ripped it from the mount to throw under a bus. Then the "Duh-o-meter" went off and I realized what I'd done. Once I set it back to Auto mode it worked great ... I'm just glad I was alone so no one could make fun of me.
doctorharrison
09-08-2007 02:58 PM
660, 9184397, davidson, forum, garmin, harley, install, installation, installing, power, registration, supplies, ultra, wiring, zumo
