HELP! Alarm flashes, doesn't recognize my key fob.
All the bikes that come from our local dealers here, come with the code set as 31313. First thing anyone should do is reset it to something they can remember. I could probably start half the bikes in the BC Lower Mainland because a lot of owners don't bother to change it. Once you do set your own code you should practice using it so when you need it you CAN do it, or at least carry the instructions in your wallet.
Turn the ignition off then on. Immediately press both turn signals until the five lines appear in the speedometer. Press the left turn signal three times then the right once. then press the left turn signal once then the right once, then the left three times and the right once, then the left once again and the right once. To finish, press the left turn signal once and the right once.
The left button sets the number and the right is like pressing "enter."
Sassafrass (06-21-2018)
