Adding a Street Glide Fairing to our Road King
#61
Attached is my parts list (probably missing a few odds & ends, but complete for the most) & a wiring diagram of how I wired everything from the RK harness to the interconnect harness. This will work for an '06 but I can't guarantee any other years.
For the parts list, get the parts manual for your year bike; this is a great source and will make it easier coming up with a complete list.
For the wiring, if you don't have the shop manual, get one. It is very helpful. As I stated in a previous post, it's pretty straightforward.
I'd be happy to answer any questions.
#62
If you're going for a full conversion, you'll have to extend most of the wires from the RK speedo & indicator lights. I also extended the ignition switch connections and replaced my steering lock with an ignition from a Touring model. One note, make sure you get an interconnect harness from your year model as they change from year to year. It will make things easier assuming you have the shop manual. BTW, I finished converting mine last week with the exception of paint and I'm still waiting on a new dash.
What kind of dash did you go with?
Where did you get he ignition switch reasonably priced?
Thanks
#63
A little of both; I cut the connectors (speedo, idiot lights and ignition) from the RK main harness. I extended those connections forward to the fairing and put on the connectors that mated to the interconnect harness.
The dash I'm going with is from http://www.powerproductsparts.com/ He is making me one to fit the RK tank without a filler hole.
The ignition (switch & ****); I was lucky enough to score an inner fairing cap with the ignition and dash switches from eBay. I still have an additional cap and dash switches (spot & accessory) if you're interested. I also have a brand new ignition **** w/o keys (long story)...I think you can order new keys from HD.
#64
halldave444@gmail.com (12-11-2021)
#65
I am also very interested in this can you also email your findings to me, thanks John
johnlaterra@sbcglobal.net
#66
#67
My buddy did the conversion to a '05 RKC and it looks sharp. He left the speedo and ignition switch in there current locations and put speakers in the holes (Two 3" mid ranges, and two tweeters plus the 51/4" speakers) for the stereo. I'll see if I can get pictures from him but the bike looks sharp.
#69
Slick, they are about 3 inches wider, I couldn't use the original bars with my conversion.
the switch cap made things hard to line up.
If you go purchase one of those aftermarket fairings, you won't have to do anything.
I just choose to put the OEM equipment on my roadking.
Depending on your taste, I wanted the Ultra equipment.
#70
