Tour Pak elect. connector for Road King
I recently purchased a Tour Pak for my 02 Road King and would like to hook the lights up from the tour pak connector .
Do Road Kings have the necessary connector bundled up somewhere ?
I read the other threads on the Road Glides and Street Glides having connections but can't find them on my Road King .
Any help would be appreciated !!
Then you'd need the 70646-00 for $30.95. Check under the seat for the connector (not the accessory circuit) for the interconnect for the tour pak. It might be there if your bike has it.
The Road King does not come with the tour pak wiring harness that is part of the main wiring harnesses on the other Touring models; at least they don't according to the wiring diagrams in my '04 HD Touring Models Service Manual.
Your easiest alternative is to use the accessory connector under the seat on your bike. It's a Deutsch DT connector so you will need the mate for it as well as the pins/sockets. The connector you need, and the pins/sockets are the same ones used on the HD tour pak spoiler/LED. PM Dawg and he can give you the HD part nos.
Good luck with your project.
