Engine misfires when first starting out
Old 09-13-2009, 06:08 PM
jcowan's Avatar
jcowan
jcowan is offline
Stage I
Default Engine misfires when first starting out
cheers all,
I've searched on this topic and haven't found anyone that has posted the exact (or close to) my problem. I'm not a wrench-head so I'll try to give you as much info as I can.
I have a 2000 Electraglide - with a carburator. In 2008 I had louder pipes installed and the carburator was re-jetted to match the new pipes. Since then, about twice a summer (NY, can only ride 6 months a year), I have this problem:
I fire up my bike, it starts fine and it idles fine. I put it in first gear and take off. The engine will start missing, popping, sputtering, coughing, wheezing, etc... It is hard to keep it running. If I can power through these spells and keep the bike running, they last for about two to five minutes. Then, the bike settles in and runs fine. This never happened before I had the new pipes installed. I've also noticed that when these spells start to happen, the engine will pop or miss, once or twice on a ride. The next time it will happen more often, and then I get into the full blown missing, popping, sputtering, coughing, wheezing, etc... sessions. It gets worse with each ride.
I've had the bike looked at and the carburator re-jetted again, the carburator cleaned, and new plugs installed. Then it runs fine for a few months and repeats. I've getting tired of paying Harley mechanics for fixes that do not last.
As I noted, this only seems to happen about twice a year; the beginning and the end of the riding season for me. April to October. I'm wondering if colder air affects this? Could it be the jets are not operating correctly in cooler weather?
I was told when I bought the bike to run high octane gas in it ( 93 grade ). I was recently told not to do this and to run 87 octane. Does this matter?
Onother mechanic mentioned the Ethonol (spelling) in the gas now, might be causing these problems. But again, only about twice a riding season.
With this current session, a mechanic suggested adding a bit of Dry-gas to the tank. I've done that but it hasn't helped.
I have a friend who has the same problems only worse. He owns a sportster. I'm thinking there must be others out there with this problem and hopefully there is a common fix.
Any ideas or thoughts would be appreciated.
Thanks for reading this and for your ideas.
JCowan
Old 09-13-2009, 10:11 PM
dgretz's Avatar
dgretz
dgretz is offline
Check for moisture in the plug wires. Had some in mine and it sputtered until they either warmed up and dried out or this last time when I discovered it was able to let the water drip out of the spark plug end
Old 09-13-2009, 11:06 PM
Bigwillie's Avatar
Bigwillie
Bigwillie is offline
Sh*t stirrer!
Old 09-13-2009, 11:16 PM
emwolb's Avatar
emwolb
emwolb is offline
are you letting the bike warm up using the enrichener, harleys word for choke? it is essential that you allow the motor to warm up a bit before taking off, so the cylinders and pushrods can grow to their running size. this was a common problem that riders had when the twin cam motor came out, and was responsible for blown base gaskets, or head gaskets. take your time and when the fins on the heads are hot, you'l be able to feel it with your hand. don't leave the enrichener on for too long, as you can end up fowling your plugs using it too much. hope this helps.
Old 09-13-2009, 11:50 PM
myred55's Avatar
myred55
myred55 is offline
Originally Posted by jcowan
cheers all,
JCowan
WELCOME TO THE FORUM!
Old 09-14-2009, 01:51 AM
paguy's Avatar
paguy
paguy is offline
The plug wires are a possibility. Another may be any rubber gaskets or fittings along the air or fuel intake.
Krazy8s
06-06-2013 09:15 AM
Ipara
09-15-2012 08:25 PM
mucklepilly
04-09-2010 08:54 AM
jasvncnt
08-31-2006 10:42 AM
bragz
02-21-2006 01:30 AM
Quick Reply: Engine misfires when first starting out
