How do you fix a loose shifter shaft?
Old 12-01-2009, 05:19 PM
BM83's Avatar
BM83
BM83 is offline
I would start by checking if the lever on the engine side of the primary is pushed against the primary case as far as it goes and is tightened properly.
If not, loosen the outer levers and slide out, get the inner lever set and tightened, then push the outer levers into place and tighten.
Old 12-01-2009, 06:12 PM
Wally's Avatar
Wally
Wally is offline
I can do that, but I'm not thinking that will help.
Old 12-01-2009, 07:30 PM
BLKBAGGER's Avatar
BLKBAGGER
BLKBAGGER is offline
Originally Posted by Taterdigger
You might give this a try. Remove the shifter shaft, clean the shaft and and bushings in the primary. Use heavy bearing grease and reassemble the pieces. The notches in the the shaft are large enough that you can have someone squeeze the shifter and lever together while you tighten the bolts. I had the same problem with the shifter rattling after removing the heel shifter and it worked for me.
I also do this on my bike. I also used thin "O" rings to keep the grease in. Stays nice and tight for a long time.
Old 12-01-2009, 08:17 PM
gabulldog's Avatar
gabulldog
gabulldog is offline
I think the company "Pingle" (the electronic shifting guys) makes a shifter shaft with a grease fitting made on the end. Just another possible fix, still have to replace the worn bushings. Don't remember the price but it can't be higher than a HD part.
Old 12-01-2009, 08:37 PM
BM83's Avatar
BM83
BM83 is offline
I guess I should have read all of the posts. Didnt see where you had already replaced the bushings. duh
Old 12-01-2009, 08:42 PM
CrashX's Avatar
CrashX
CrashX is offline
So I changed the bushings, literally a ten minute job. The shifters are much tighter, but there is still some wiggle.
If I wanna get really picky, I'll change the shaft.
Does anyone know the part # for the shaft? Price?
Maybe it's cheap..........probably not though, Eh?
p/n 33709-82a
under $20.00
Old 12-02-2009, 01:49 PM
etstrine's Avatar
etstrine
etstrine is offline
I'm thinking about trying the E-Z Spacer.
http://bellsouthpwp.net/e/z/ezbrake/index.htm
Looks like this will take care of the problem and should keep it from coming back. Anyone have any experience with this?
Old 12-02-2009, 03:20 PM
skratch's Avatar
skratch
skratch is offline
Received 4,187 Likes on 2,454 Posts
dont have the stock number handy, at work. but one of our riders had his splines go out while on the road and picked up a new one at sturgis hd for less than $20.00
Old 12-02-2009, 06:18 PM
Wally's Avatar
Wally
Wally is offline
It can, and it is, but a shaft from HD for $20 and a friend with a machinists license, might be the answer.
Old 12-02-2009, 07:11 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Machinists licence?
Do machinists in Canada have to be licenced?
Quick Reply: How do you fix a loose shifter shaft?
