Screamin Eagle slip on for 2010 street glide
Might want to re-check with the dealer. I bought a 2010 SG on Friday and he said for the SE Nightstick, the D&D Fatcat, or the Thunderheader slip on (all have already released their new slip on for the 2-1) for the new '10 SG it required a MAP Download. I'd think he is right too, esp if you don't do a Stage 1 breather because the pipes already get alot hotter than other model years because of the CAT in the pipes on the '10s. Also I heard the SE and it wasn't much loader than stock to me. No way I'd buy it.
Your dealer is trying to screw you. You DO NOT need a map update for just a slip on muffler. When you go to changing head pipes and intakes you need to update the ECU, but not with just a slip on muffler.
The consensus seems to be that I don't need to do anything besides add the slip ons. The only reason I might do a stage I is that the dealer is giving me 25% off all parts and labor for anything I do before I pick up the bike. So with that in mind, I may just do a little more than just add the slip ons. Otherwise, I wouldn't.
Watch out, some of them try to rob you blind.
No new high flow intake = No need for download.
Be advised, you need the high-flow intake and download. The bike rides SO much better once it's breathing more freely. It really makes quite a difference. If you're getting 25% you should do the whole thing. It's a lot cheaper with our 1/2 exhausts anyway.
