FloorBoard Rattle
FloorBoard Rattle
I have an 08 Electra Glide Classic bone stock.There has been a rattling noise coming from the right front lower portion of the frame near the floorboard when I almost come to a complete stop. I originally thought It had something to do with the rear brake pedal, or the brake rigging. Well Yesterday I found the culprit, the right side floorboard is rattling at the front of the board where it bolts to the floor board bracket. The bracket, and floorboard as well as the rubber portion appears to be OK. The bolt is tight, It looks like the shaft on the bolt is smaller than the hole in the bracket and allows upward and downward movement causing an annoying rattle!! due to movement even when the bolts are tightened. I even tried swapping the front bolt for the rear one and it still rattles!!!
Any suggestions and or comments would help thanks Bill
An old thread, and a new (to me) solution
