Error Code 99 Loss of Idle Speed Control
Greetings,
43,000 miles and going strong, well sort of. I got an error code 99 Loss of Idle Speed Control on my 2003 FLHTI when coming back from Laconia. My speed sensor has been eratic. I removed, cleaned, and replaced the speed sensor. Will a defective speed sensor result in a loss of idle speed control?
James
James
RE: Error Code 99 Loss of Idle Speed Control
Crazy,
Yes, a faulty speed sensor will affect your engine's idle. If you've cleaned it and it still didn't help, you need to replace it. Your speed sensor handles: idling, turn signal cancellation, cruise control, and speedometer.
ORIGINAL: CrazyMC
Greetings,
James
Greetings,
James
Development!
It appears that my rough idle condition only exists when at 1/2 tank of gas or less. Bike also bucks at cruising speed. From my forum search it appears to be a internal tank hose leak or faulty regulator. Anyone with suggestions please let me know.
Thanks,
James
Thanks,
James
Success!
It was the hose between the fuel pressure regulator and exterior fitting on the gas tank. HD designed the hose too long and over time (45K miles) the ribbed hose developed pinholes due to rubbing against the inner wall of the gas tank. When I went to the dealership they sold me a redesigned (shorter) hose. While at it I changed out my fuel filter. The bike runs like new! I can only wonder how long I have been riding with this condition. I did use the old hose as protection for the new one! I cut the old hose long ways and rapped it around the new one. This was just incase if it should ever rub in the tank again! This should definitely be an FYI for long distance riders!
Take Care and Ride Safe!
James
James
CrazyMC
07-15-2006 11:01 AM
