How to use single cylinder mode?
Old 10-20-2009, 07:59 AM
Cerulean's Avatar
Cerulean
Cerulean is offline
6th Gear
Default How to use single cylinder mode?
Friends:
My Bike is a 2006 FLHTPI I think it's a Police Special.
I just got my bike and would be grateful if someone could tell me a couple things:
1. How do I activate/deactivate the single cylinder "Parade" mode?
2. What does the red "P" on the dash indicate?
Thanks in advance amigos!
Migs
Old 10-20-2009, 08:21 AM
brettnbama's Avatar
brettnbama
brettnbama is offline
On my 09 RK, the parade mode kicks in automatically once the engine temps hit a certain point. It only kicks in if stopped and in neutral or in gear with the clutch in. You can enable/disable it by turning the ignition switch on and the run switch, then roll the throttle forward and hold it for a few seconds. The cruise light will flash green if its on, and red if its off. As for the red P, I am unsure, I am not sure I have a red P on my lights
Old 10-20-2009, 08:32 AM
marcparnes's Avatar
marcparnes
marcparnes is offline
Are you sure it's actually a "P"? No "P" light on my '09. Did you look in your owner's manual yet?
Marc
Old 10-20-2009, 08:37 AM
HDRider2002's Avatar
HDRider2002
HDRider2002 is offline
I had a "P" on my speedo on my 02 FLPHi, it would only light up when the switch was in "PURSUIT" position so the officer would know his pursuit lights were on.
harleyflyboy's Avatar
harleyflyboy
harleyflyboy is offline
What model and what year, they are different. The '09 touring bikes you enable and disable the single cylinder mode by twisting the throttle past idle for a few seconds, then the cruise control light will either flash green or amber depending on if it is enabled or disabled. The "p" is for poser
Old 10-20-2009, 08:42 AM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
I thought it meant the bikes transmission was in Park LOL....
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
Originally Posted by harleyflyboy
................. The "p" is for poser
That explains why my bike doesn't have one. I was looking all over for it........... LOL
Old 10-20-2009, 09:44 AM
BigD64's Avatar
BigD64
BigD64 is offline
You need to post the year and model of your bike. On 08's and up you can turn the rear cylinder cut off on and off yourself on the 07's it's a software switch activated at t he dealer. If you have a police model bike FLHTP, or FLHP the "P" on the dash is for the pursuit lamp,(red switch on the right controls.)
Old 10-20-2009, 10:18 AM
Cerulean's Avatar
Cerulean
Cerulean is offline
6th Gear
Hi all:
Thanks for all the input guys!
Migs
Old 10-20-2009, 10:28 AM
Cerulean's Avatar
Cerulean
Cerulean is offline
6th Gear
HDRider2002:
Can you elaborate on the Pursuit position and how to enable disable it? What is it for and what should it be on normally?
Thanks in advance,
Migs
Quick Reply: How to use single cylinder mode?
