2010 Ultra Limited 103" and new cams
has anyone tried the SE-259E cam set with a factory 103" motor, does anyone know which cams are factory on the 103" in the Ultra limited model, I would like to upgrade from them, I am thinking it is the 255 set????? anyone upgraded yeat, I am going with new pipes (without a cat) new old stock (prior to epa bullshit) screamin eagle mufflers, a compact Heavy Breather Screaming Eagle intake and sest tuner and want to put the new cams and pushrods in asap to be able to complete the upgrade all at once before tuning.....
anyone done this yet?
Stock cams are same as stock 96 cu cams. 255 seems to be conventional wisdom for the 103 unless you're modifying compression which of course would require more extensive engine work. Matching cam to compression, IMO, is as important as aything to the overall riding experience. I'd probably go with the 255s myself (in fact that's waht I plan to do with my Limited).
