Starting procedure for a 1980 flh
Old 11-02-2009, 08:42 PM
rickey67's Avatar
rickey67
rickey67 is offline
Stage III
Default Starting procedure for a 1980 flh
Looking for info on starting 1980 flh I seem to flood the engine.My repair manual doesn't say how to start using throttle choke
Old 11-02-2009, 10:06 PM
acftdr's Avatar
acftdr
acftdr is offline
Do you have the separate "choke" on the carb like an S&S? If you're flooding it, don't choke it. If you think it's flooded, crank the throttle wide open while you crank the engine. This will clear out the gas and lean the mixture back out.
Old 11-03-2009, 04:47 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
Assuming it is stock, you are right, it should have a choke as you describe. It may also have an accelerator pump, which pumps neat gas into the engine if the throttle is twisted!
So to clear the flooding, twist the throttle open slowly. In a bike of that age there are many things that may have got old that can cause problems. I suggest you post again in the Shovelhead forum. See if those guys can help!
Old 11-03-2009, 04:57 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
On my factory stock '84 I would just pull the choke all the way and when it started push the choke in about half way till it started warming up. You may well have a worn out float valve (needle) in the carb that needs to be replaced. Easy job and cheap part.
Good luck,
John
Old 11-03-2009, 05:09 AM
BAGGERNATE's Avatar
BAGGERNATE
BAGGERNATE is offline
Have owned a 79 and a 81 shovel in the past. One other thing you might check is if you have flooded it several times as it seems you have, change plugs. Plugs can look good have correct gap ect. but flooding can saturate the porceline and make it hard to start. They can even look dry. That has been my experience.
Nate
Old 11-03-2009, 12:21 PM
widowmaker221's Avatar
widowmaker221
widowmaker221 is offline
Sounds like an S&S carb with an enrichner which is not the same as a choke and can flood the motor if not used correctly. My procedure for this carb is to open petcock, turn mtr over a few times, twist throttle about 4-5 times, lift enrichner approximately halfway up and push start. Repeat as needed and close enrichener when idle ready.
Old 11-03-2009, 01:14 PM
frog13's Avatar
frog13
frog13 is offline
I've run Keihin, Bendix, S&S and SU on my shovels. I almost always avoid the choke when starting. Shovels tend to flood easily, at least mine. If it is flooded, you can try to start it with the throttle wide open and the petcock off. Once it starts, open the petcock. If it's flooded you do not need the choke, it already has too much fuel for the air. I have a kicker, so if I flood, I shut off the fuel and ignition, open the throttle wide open and kick it through four or five times. Turn on the fuel, don't touch the throttle, turn on the ignition and it will fire off next kick. If you have a Keihin, start with one twist of the throttle, see if that's enough to prime, work up from there if needed. It's all about figuring out which carb you have and how they dump fuel, whether it's by throttle pump or enrichener.
Old 11-04-2009, 08:17 PM
rickey67's Avatar
rickey67
rickey67 is offline
Stage III
Smile Reply to starting problem
Thanks for all the help on starting my bike started much easier with just the choke out no throttle.
Old 11-04-2009, 08:24 PM
dan11809's Avatar
dan11809
dan11809 is offline
Turn the ignition off,hold the throttle wide open and don't realease it while kick staring it three times.Continue to hold throttle open,turn ignition on kick again and engine will fire!
DanMan1
Shovelhead
09-25-2013 07:34 AM
Rob Mengel
Shovelhead
09-09-2013 08:07 PM
brianrider357
04-18-2010 09:19 PM
aortaflh
Shovelhead
06-28-2009 09:39 PM
Quick Reply: Starting procedure for a 1980 flh
