EZ-UP Center Stand vs Harley Center Stand
Old 11-09-2009, 06:20 PM
Texas Fat Boy's Avatar
Texas Fat Boy
Texas Fat Boy is offline
I had the Wheeldock on my '08 Street Glide but when I bought the '09 I sold it and never even consider buying another one.
If I ever did it again I would buy the Harley one because it has "adjustable legs".
If you are ever planning on raising or lowering or even changing rims you will need the adjustable one.
Plus I only used the Easy Dock in the garage. Any thing not level in public is gonna cause you some trouble.
Park up hill and your rear tire will only spin.
Park down hill and your bike will roll off the stand by itself, while you are gone.
Old 11-09-2009, 09:12 PM
jamcgowan's Avatar
jamcgowan
jamcgowan is offline
Originally Posted by Texas Fat Boy
...If you are ever planning on raising or lowering or even changing rims you will need the adjustable one.
Not entirely true...just place a 1/2" piece of plywood under the stand and the rear wheel will be lifted off the ground.
...Plus I only used the Easy Dock in the garage. Any thing not level in public is gonna cause you some trouble.
Definitely possible, but, a little care in selecting parking sites takes care of that.
I have the Easy Up center stand...took 5 min to install and works wonderfully. Mine has the chrome extension so it looks good too.
Old 11-10-2009, 04:12 AM
jkoch09ultra's Avatar
jkoch09ultra
jkoch09ultra is offline
For those with an air ride system just drop the stand then hit the down button on the air ride and almost 900 lbs goes down on the stand. It will never roll off the stand. I bought the shorter Wheeldock stand. To leave I raise the bike with air and drive off. I do it while on the seat with no effort or worry everytime I park. If I park it slammed I use the Jiffy stand.
Old 11-10-2009, 06:34 AM
Texas Fat Boy
I'm just warning a Brother on what could and will happen. It was an easy install and it did look good, I'll give you that.
Old 10-23-2012, 09:13 PM
eberg's Avatar
eberg
eberg is offline
I know this an old post, so hopefully you guys are still out there. If needing a center stand for "maintenance", would you go with a center stand or a wheel chock? And or one of those lift deal'ys?
Old 10-24-2012, 12:04 AM
Ultra89Rider's Avatar
Ultra89Rider
Ultra89Rider is offline
I have both. I have the Harley Center Stand for storage And a lift for maintenance.
When Harley changed frames, the center stand changed too.
I found the adjustably of the legs makes a big difference from the EZUP Stand.
A big plus is how the Harley stand tucks up when not used.
Djcamis
2014-2023 Touring Models
26
03-04-2020 02:55 PM
Thetatornater
12-10-2017 06:26 PM
beanoboy
09-14-2017 08:25 PM
cmc seabee
12-28-2011 02:49 PM
Blackisfast
05-03-2008 02:17 PM
Quick Reply: EZ-UP Center Stand vs Harley Center Stand
