Royal Purple User Questions?
Royal Purple Users Questions?
Not trying to start and/or rehash an oil thread, just looking for some feedback from other Royal Purple users. Bike is a ’07 Ultra with 103 Stage II, 255 cams, and IDS. Bike has been dyno tuned using a SERT. Over 11,000 miles on the build. I’ve run HD Syn 3, Mobile 1, Amsoil, and now Royal Purple Max Cycle. All 20w50 weight. Amsoil was the best, so far, until I tried the Royal Purple. Here’s what I’m observing after an oil change with Royal Purple; picked up 5 to 7 PSI oil pressure when cruising @2800 RPMs temperature consistent for my test @ 55 degrees F (engine oil levels the same), engine seems to start easier/quicker and it appears engine performance has improved slightly (running on flat, level ground used to be approximately 2,750 RPMs @ 30 MPH in second gear, now approximately 2,600 RPMs in second gear for 30 MPH. Any other Royal Purple users experience this?
OK I confess, I'm a skeptic
This is the second time for me as my first time was on an RV web site a couple of
years ago. Make the engine run smoother, started easier, ran cooler and lasted
longer ........Well that was how HE saw it anyway. He didnt have to convince me
as I have use the Synthetic stuff for years say 25. And just yesteday picked up
my first BLURPE SYN for the tranny in the 97 RK. They are proud of dat stuff.
Tenn.Vol.
Tenn.Vol.
I've been using RP for a couple of years but don't remember those kinds of numbers.
FWIW, the regular automotive RP is considerably less then the MaxCycle and works just fine in the engine. I've use to use the MaxCycle in the primary but changed to either ATF or 10w50 Spectro some time ago and got better results.
As a note, I didn't notice any RPM change other than 2nd gear. Engine just seemed to rev smoother in all gears.
NO new rear tire, just changed engine oil and filter.
Also, I don't have any connection with Royal Purple. The last couple of years I've been a regular user of Amsoil and Mobil 1. Just thought that I would give the RP a try.
Why you ask? Because only the best kind of people come from Upstate New York.
Did I mention I am originally from Auburn??
