s and s 124 kit good or bad?
Good? I think its a great kit. But you still need someone very competent to put it together. You need someone who can machine the cases right and timken the bottom end.
The kit itself is a quality product, the forgings and machining is A grade. I think the S&S heads are among the best around, triple valve springs and quality machining. Gear driven cams are a no brainer for 640 thou lift as are forged roller rockers and forged supports.
Be careful what exhaust you run, it will greatly affect performance. What do you have in mind??
Some photos of the kit:
http://s207.photobucket.com/albums/b...z/Micks124SnS/
My bike ran 12.25 @108 mph with the screen on and the bags on, tools in the bags etc (street trim). We weighed 1050 lb on the weighbridge at scruiteneering. I cant hit her hard in first, she either spins or lifts the front wheel and I cant ride that well, so I feed the throttle in 1st and hit her hard once the clutch is out in second. At that stage I was running the canned map from S&S and since then we done some dyno time have picked up a bunch more torque in the mid range. Still have not got the top end right and she still wants more fuel in the mid range and the VE tables are maxxed out. Once I get some more $$ and some time we will go and chase the top end, but as a street engine it is fine. With some more dyno time there is a 11 second pass there in street trim which is the target.
To ride it is just fantastic. At 80mph in 6th you can just roll on some throttle and pull 110 in no time. Its a totally different cycle.
My bike is my daily ride, so I wanted big grunt every day and the SE kits that keep the flimsy stock crank, chain driven cams and tapered con rods just didnt impress.
I average around 38 mpg, best 43 when ridden real light with the HOG group and worst 34 when belted keeping up with mates on sport bikes. What more could you ask for?
the only concern i'd have with the 124 inch motor in the harley cases, is that you gotta remove a lot of metal to accomplish that much bore. had you considered either of the two big Jims motors? the cases are made much thicker to accomodate the added stress of the increased size and power that the big motors can produce. just a thought. the jims motors can be gotten through your harley dealer. google it, lots of info in the jims site. kingX3, that's gotta be one whacko bananas ride, your blue king. bet it's a blast to ride.
kingkingking, just went to see the work as your motor was being built. looks like a top quality build going on there. too much $$$ for me, but it's gotta be great. looks like the 58mm throttle body is also a throttle by wire so your cruise still works? awesome job. i'm very envious now. quite impressive, bet it sounds wicked too.
I looked at the Jims, read some reviews and they were mixed.
The Jims runs chain driven cams (so I would have changed them to gear) and by the time I fitted the throttle body, AC and pipes it was thousands of $ more than the S&S.
My stealer wasnt interested in supplying the Jims either, and warranty was an issue. Hence the S&S.
With the Timken bottom end the HD cases are supposedly more than tough enough. Time will tell I geuss.
Yup, she runs the SE 58mm throttle body and SE injectors, with SERT. So cruise works just like the 96.
As for the sound:
http://www.youtube.com/watch?v=-Tj88bFf79Q
http://www.youtube.com/watch?v=a2Ty4VnLXlE
As for the sound:
I wanted a crate S&S 124, that would have been the best solution. Pull the 96 and put it in the shed, bolt in the 124 and off we go. Not an option unfortunately, so I had to spend $$$$ on machining and labour.
IF the story about HD sueing S&S is true then that is a true dog act, after all S&S helped HD develop the Evo. Anyhow, HD were probably trying to ensure they sell more SE gear. HD did a deal with Jims and that why you can buy a Jims crate 131 but no other brand.
Anyone got anything that points to this?
Never heard that before - Regardless I'm sure there would have been contractual limitations as to what S&S could do. I'd always thought S&S liberally ripped off the MoCo once the original patents, limited as they were, expired and that was in no small part why the TC was developed (and patented). Of course Harley wasn't particularly good at managing their IP until maybe 10 or 15 years ago.
Perhaps you mean that S&S developed Evo based innovations that the MoCo introduced during the life of the Evo? That I'd believe.
