Depends. What year's the bike? If you have stock exhaust with that blasted crossover you'll have to remove the whole shabang to get the cam cover off. Then you'll need new exhaust gaskets. You'll have to remove your right rider footboard too. I suggest tucking wax paper or aluminum foil between the case and the clutch cable and let it lay into a drain pan as some oil will come out.
on a twin cam yes,its just a cover.put a drain pan under it,you`ll get some oil out.when you get it back on,teliscope one of the p/rod tubes and put about 1/4 quart of oil back in it before firing
kirby
facebook: kirby apathy
kirby
ah why not just put the lost oil back in the thru the oil fill hole LOL. actually when I do this I run both tires on to a 2X4 and it leans far enough over when on the kickstand that I do not loose a drop of oil. I have a 2:1 exhaust and some Soos floor board extenders and do not have to remove either.
