Arrrgh! Exhaust leak at rear cyl. (did Forum Search &?)
I did search the Forum on this and now not sure which is right.
I finally said screw the chores, I'm getting at least one of these exhausts on these bikes. Installing Vance and Hines PowerDuals on my Road Glide and when all was said and done, I have an exhaust leak at the rear cylinder and though much harder to hear, possibly the front too. Before my exhaust ever came in, I went and bought the H-D SE exhaust gaskets because they looked like compressed stainless steel which got me thinking "well, that should last". The V&H headers came with gaskets that had a same flat woven look, but looked like some composite rather than steel. So I didn't use them. Knowing that I now have to tear her down again (dammit!), I did a search on the Forum and noticed a few interesting things regarding who says to use what and why. The OE headers do have rounded mating surface whereas the V&H have a flatter mating surface. Since the OE gaskets appear to have that taper, would that not make my exhaust leak worse? One person says that the SE gaskets are only best for the flatter pipes (like mine), but mine leak.
Since the V&H gaskets look the same as the SE ones, is there a better choice, or do I just go with the V&H ones? Are those copper wire style ones good for H-D? So, I'm confused as to which gaskets are truly the 'ideal' ones. Since they're only exhaust gaskets, I'm not concerned about cost, just want the best so I won't be doing this again.
Now for your humor, good thing I had the AutoTune O2 sensors to use in the new headers because the rear OE O2 sensor stripped while removing it. Somehow the threads on the OE header aren't too bad, but that sensor is toast. And, because I don't have a Windows PC to use yet for the AutoTune set-up, the new O2 sensors are nothing more than expensive plugs!
Please, tell me which gaskets are best, especially if you happen to be running the PowerDuals. Huge thanks for any help!
In closing, I'm hoping that soggy lower rpm will clear up once my exhaust leak is cured.
OEM harley gaskets for me for all my exhaust needs.
They will crush and seal off a potential leak. The only reported potential issue if you're not careful is they will crush and possibly protrude into the exhaust port area.
The SE gaskets are more problematic than they are worth IMO. I have the D&D FatCat and the portion of the pipe that inserts into the exhaust port on the head is the perfect design for proper sealing and I STILL used the OEM gaskets over the SE gasket. I've had to redo exhaust gaskets while doing my build and that was enough to let me know the SE gaskets suck.....even as meticulous as I was when I installed them......leaky.
Now, on to a supplier of Cometic I go a-huntin'.
Thanks again.
Just used SE gaskets but haven't fired engine yet (on Softail). Got me worried now. What's the trick? I just want to make sure I've not screwed up . . .
Well if I have a problem it's not that tough to fix . . . I'm not running a cross-over so there's no link between front and rear exhaust. Makes install/uninstall pretty straight forward. The gaskets I took out look like the same SE gaskets.
Dawg, if you don't mind me asking, is the manual's way of tightening the exhaust flange nuts the best regardless of pipe or gasket?
Thanks.
