? on detachable tour pak mounts
I was on the H-D site this morning and noticed that they show 2 different detachable tour pak mounts. They show a one up and a two up detachable tour pak mount. I've been using the one up mount as my two up mount for the wife, my question is should I change to the two up style of mount? Is this a possible safety issue, has anyone had any problems using the one up mount as a two up mount? The first pic. is the mount I've been using and the second is the mount they say to use.
Here's the factory descriptions;
Detachable Solo Tour-PakŪ Mounting Rack
The Solo Tour-PakŪ Rack moves a Chopped or King Tour-PakŪ forward to a comfortable back supporting position. The rack is designed to position the Tour-PakŪ for solo riding and is adjustable over a 3/4" range. Simply remove the Tour-PakŪ from the convenient detachable hardware, add a passenger pillion, and the bike is ready for two-up riding. Tour-PakŪ, Passenger Backrest Pad and Docking Hardware sold separately.
53260-02
Detachable Two-Up Tour-PakŪ Mounting Rack
Change your riding style in less than 60 seconds. The ultimate in touring flexibility, this Tour-PakŪ Rack makes the convenience and protection of a Razor-Pak, Chopped, King, or Leather Tour-PakŪ Luggage System a simple on-and-off proposition. Simple turn latches mount the rack to the bike's docking points, and allow you to replace the Tour-PakŪ with a detachable sissy bar upright for around-town cruising. The chrome-plated Detachable Rack positions a Tour-PakŪ behind the passenger pillion, and allows the passenger to use the luggage as a supporting backrest. Adjustable over a 3/4" range, the Tour-PakŪ can be located for maximum passenger room and comfort. Tour-PakŪ, Passenger Backrest Pad, and Docking Hardware Kit sold separatly.
53276-04
53260-02
53276-04
First, ignore any detachable product that is for '09 or newer models--they aren't intended for '08 and older bikes.
Second, the solo detachable tour pak rack uses the forward mounting points, i.e. the same mounting hardware that is used for a passenger backrest. If that's what you have, you are fine.
The two-up detachable tour pak rack uses a different set of mounting hardware. That hardware is used only for the two-up detachable rack; has nothing to do with the passenger backrest.
Don't know what "safety issue" you have in mind.
Carl
Carl
read again
53260-02
53276-04
53260-02
53276-04
The 53260-02 says "Detachable Solo Tour-PakŪ Mounting Rack". Fits '97-'08 Road KingŪ, FLHT, FLHX, and FLTR models equipped with solo seat and required docking hardware.
And the 53276-04 says "Detachable Two-Up Tour-PakŪ Mounting Rack". Fits '97-'08 Road KingŪ, FLHT, FLHX and FLTR models equipped with required docking hardware. FLTR and FLHX models require Antenna Relocation Kit P/N 76326-00A. Does not fit with Layback License Plate Mounting Kit.
I just want to be sure using the 53260-02 solo mount is OK to use for the rear two-up mount.
The solo mount will not work as a two up mount.
It physically will not "mount" as the mounting posts are in different places - I think. (solo vs two up)
If you have a detach mount on your bike now and it is in the rear, and works as a two up mount, you probably have the two up mount....
The two up mount pictured on the right way above is a two up mount for an 09+ touring bike and does not apply to your 05.
Yes, the listing is for a two up, but it's the wrong picture for your bike is all I'm saying...
All detach mounts for 08 and below (yours) have that U-shaped round bar of which the tourpack or whatever mounts to.
The solo and the two up both have round bar. All mounts for 09+ have just a flat piece of metal...
So... if you are running a "mount" and it's working for you as a two up... it's probably the two up mount...for an 05.
lp
Ricky Kyles (08-02-2022)
