Accessory switch ?
Old 12-22-2009, 03:34 PM
kjkustoms's Avatar
kjkustoms
kjkustoms is offline
Question Accessory switch ?
2008 FLHX. Can anyone tell me , before I tear into it, the accessory switch on the inner fairing,beside the cruise control switch, I would like to connect my Heat Demons grip warmers to that switch, it is a dummy switch as far as I can tell, the light comes on but does nothing. How can I go about hooking something up to that? Any help is good.
Old 12-22-2009, 03:36 PM
dawg's Avatar
dawg
dawg is offline
Received 2,955 Likes on 1,711 Posts
It controls the accessory connector located under your seat
Old 12-22-2009, 03:41 PM
kjkustoms's Avatar
kjkustoms
Can you elaborate on that, The bike is "new" to me, and I really only know Dyna's, Touring is a whole new game, Thanks.
Old 12-22-2009, 03:52 PM
CruzN's Avatar
CruzN
CruzN is offline
Under the seat is a connector, you can buy the other end at the HD store with a cigarette lighter plug on it ($20). Use the plug or just take it off and connect to what ever device/plug you want. The accessory switch controls on/off. but remember it's off without the key on. The connect on my FLHT is located just in front of the battery.
Supplemental 12v Power Point
Old 12-22-2009, 03:57 PM
bagman1's Avatar
bagman1
bagman1 is offline
Off hand do you know what the fused rating on that circuit is? I have a RG and I never knew the plug was under the seat, sounds like a perfect place to feed an electric clothing circuit (pants, vest, gloves and maybe socks). Thanks for the info Dawg and Cruzn
Old 12-22-2009, 04:42 PM
capt chaos29's Avatar
capt chaos29
capt chaos29 is offline
5th Gear
10 amp I believe. not near enough for heated anything
Old 12-22-2009, 04:43 PM
capt chaos29
5th Gear
On my bike it controls the power to my road zep and led running board lights
Old 12-22-2009, 05:48 PM
Sancho's Avatar
Sancho
Sancho is offline
If you hook something up to the accesorary connection under your seat, it won't work unless you turn on the acc switch next to the curise control.
Old 12-22-2009, 06:09 PM
bagman1's Avatar
bagman1
bagman1 is offline
Im not sure how much heated gear draws, but I dont remember seeing any 10A fuses, I thought they were all 15 or more.
Old 12-22-2009, 10:16 PM
Taylorized's Avatar
Taylorized
Taylorized is offline
I use mine to run the two blue lights on the rear. I wired them up to the switch so I can turn off or on when I want. You can buy just the plug and the push pin connectors for alot less than $20.
Quick Reply: Accessory switch ?
