Tour Pak Lens Removal
When I repainted the Ultra light bar, I removed the lenses using the instructions from Ride Time Technology:
http://www.ridetimetechnology.com/pdf_files/RTUPRO.pdf
Good luck with your project.
Carl
Carl
Carl
Carl
Have a look at this, not exactly what you are doing but should help.
http://www.ridetimetechnology.com/pd...ht_Install.pdf
Problem w/Lenses
It seems as if the new long rectangular lenses that mount to the bottom portionof the Tour Pak
http://www.customdynamics.com/hd_tou...d_lighting.htm
Want to mount from the inside out; thus not allowing for the chrome trim that goes around the outside to be mounted. Has anyone else encountered this? 2005 Ultra Classic
