My 09 Road King is Overheating
Old 01-03-2010, 08:55 AM
SeniorChief56's Avatar
SeniorChief56
SeniorChief56 is online now
Received 16,386 Likes on 4,711 Posts
Default My 09 Road King is Overheating
It has happened twice in less than 3 weeks. It happened yesterday, temps outside were around 70 degrees. I'm taking it in to the dealer when I find time, cuz I'm sure they will need to keep it a few days. It is still under warranty so I'm not too worried. Only changes I have made are Vance/Hines Oval Slip-ons, air cleaner and Power Commander......Any reason for the overheating? I'm thinking something to do with oil circulation, because I have been complaining about the constant ticking, which is getting louder.
Old 01-03-2010, 09:41 AM
rkoivisto's Avatar
rkoivisto
rkoivisto is online now
Default overheating
Oil circulation seems like a pretty remote possibility to me. The map in your PC is the first place to try.
What kind of riding were you doing? seventy degrees at highway speeds is one thing, but stuck in traffic, it wouldn't be unusual for it to get hot.
How do you know it was overheating? Did it go into parade mode?
Old 01-03-2010, 09:49 AM
nocarb's Avatar
nocarb
nocarb is offline
When you say it has happened twice. What has happened exactly to make you think bike is overheating?
Old 01-03-2010, 09:54 AM
Nightking's Avatar
Nightking
Nightking is offline
Sounds like you're running a little lean to me. It should not overheat in 70 * weather ,no matter how slow you were going. Did the dealer do the install on the PC.?
Old 01-03-2010, 09:58 AM
SeniorChief56
I'll have INDY retweek my TFI and see if that helps....my EIMTIS kicked in that's how I know,plus my thighs were getting hot
Old 01-03-2010, 10:10 AM
Tx_Rider's Avatar
Tx_Rider
Tx_Rider is offline
Mine has gone into "Parade mode" in cooler weather than 70 deg. That's sitting in stop and go traffic for 15 mins.
I have a Stage 1 and Syn oil too. Things get hot sitting still.
Old 01-03-2010, 10:14 AM
VTwin-Goodies's Avatar
VTwin-Goodies
VTwin-Goodies is offline
Sponsor
Received 1,930 Likes on 1,914 Posts
A Dyno might help. Sounds like it is still running way lean. Maybe the AFR is not right. That is my assumption.
__________________
Old 01-03-2010, 10:18 AM
nocarb's Avatar
nocarb
nocarb is offline
Sounds like a good idea. Thanks for being more specific it helps us figure out what may be going on.
SeniorChief56
this is not normal......the only other time it went in the mode was last summer in the 90 heat and I ride everyday,as long as it is not raining
Old 01-03-2010, 10:20 AM
VTwin-Goodies
Sponsor
You could also look into an oil cooler, although people have mixed feelings on their real value. I have an oil cooler on both of my bikes, but others I ride with don't have one and don't have issues either. Still check the AFR first.
Quick Reply: My 09 Road King is Overheating
