SE-255 and HQ-500 cam comparison
Many will recall the cam comparison on Head-Quarters' website last year comparing the SE 255 and HQ 500 cams on a 2007 Police Electra Glide (i.e. factory 103" engine). It was a neat comparison done by an HD dealer: same bike, same dyno tuner, same dyno, etc; only the cams were changed and the bike retuned.
HQ changed its website and the comparison came off the website. Since many have asked about this comparison, I got in touch with Kevin from HQ and he found the original material from the website. It's presented below:
http://
"Build Info
• 2007 FLHTPI (Police Model Touring)
• Stock unmodified top end
• HQ-TC500-HC Cams vs SE255 Cams
• Rinehart True Dual exhaust
• Tuned with a Race Tuner
The Story
One of our dealers (who is a Harley-Davidson Dealer) decided to put the Head Quarters HQ-TC500-HC cam to the test against a Screamin Eagle 255 cam as a bolt in on an otherwise unmodified motor with Rinehart True Duals and Screamin Eagle Air Cleaner.
To serve as a control, the pipes and air cleaner were installed and the bike was properly tuned before the cam swap. The results were 76.65hp and 89.06tq. The first test was to install the SE255 cam and retune. The results were 81.00hp and 96.07tq. The final test was to install the Head Quarters HQ-TC500-HC cams. The results were 86.51hp and 103.35tq.
It's important to point out that the test was unsolicited, unbiased and the tune performed by the exact same technician, in the exact same environment, on the exact same dyno, with the exact same motorcycle.
When comparing the Head Quarters cam to the SE255, one of the higher performing SE cams, there was an increase of 5.5 hp and almost 7.5 tq.
Great job Dusty...we greatly appreciate the feedback and your objective point of view."
This information is posted for information purposes only. I'm not dissing anyone who has SE 255 cams in their bike or trying to sell anyone HQ cams. And while peak numbers may change from dyno to dyno, etc., the dyno sheet provides an interesting relative comparison of the cams and you may make of it what you will.
Carl
PS: I have had HQ-0034 cams (same cam as the HQ 500, but for the 88" TC), Rinehart TD's and SE a/c on an otherwise stock bike for 2+ years/25K miles and haven't thought about a 95" build since the cam installation.
http://
"Build Info
The Story
Carl
Last edited by Harleypingman; 01-05-2010 at 10:31 AM. Reason: Confirming the engine is the factory 103" on police models
http://
"Build Info
The Story
Carl
http://
"Build Info
The Story
Carl
