What battery do you use? (other than Harley)
#31
#32
Odyssey for many years
The OEM Harley battery in my 2006 FLHRCI lasted 2 1/2 years. Bought an Odyssey PC925 in August 2008 before a ride from Florida to Sturgis. I still have this battery almost 8 years and 60k more miles and it is still running strong. I do keep a tender on it but ride 12 months/year in Maryland so if it sits more than a day or 2 I hook it up. I am ordering another one now because I know this thing has to die soon. But it was well worth the premium price!
#34
Received 2,524 Likes
#35
I see this is an old thread someone else brought out of the archives,but what the heck,i'll bite too!/LOL!!!
The best 2 replacement factory activated AGM bike batteries mfg'd in USA (PA.) for the money on the market today with proven reliability & strong cranking power are:
*Deka's ETX30L / 400CCA's (also mfg'd under mult other names) for approx $97.99 (lists for $149) to your door from Hightech battery online.
* Yuasa's GYZ32HL / 500CCA's for $132 (lists for $200+) to your door from PhatPerf parts online.
HD's OEM AGM repl battery (ETX30L type battery) for our touring bikes is spec'd @ 385CCA's.
There are cheaper batteries avail with same or higher CCA's that are mfg'd in China that have yet to earn a proven track record for reliability & long srv'c life like the Deka & Yuasa batteries have been doing for many yrs that are also mfg'd in the USA which is another + too.
BTW,i just bought & installed Yuasa's GYUZ32HL AGM battery with 500CCA in my 09 w-96" motor and that battery spins the motor over considerably faster then the prior battery did when it was new.
When i tested CCA's of the Yuasa battery it showed a over 600CCA's ,but that was with battery in 60deg F temp & battery should be @ " 0 " deg f when testing CCA's and at 32deg f when testing CA's
Scott
Scott
Lilman463 (06-06-2016)
#36
#37
Like you said they must have changed the CCA spec for your 2014 because it was 385CCA's for older large FLH touring bikes like my 09 FLHTCU that uses the larger ETX30L type battery that i am ref too.
Scott
#39
Deka in PA. mfg's the BigCrank battery along with also mfg their battery under mult diff labels for other companies too.
See below for a partial list of other names Deka mfg's their ETX30L maint free fact activated battery for.
Scott
* AUTOZONE
* PEP-BOYS
* BIG CRANK
* NAPA LEGEND
* EXTREME MEGA POWER
* FEDERAL AUTO PARTS POWER SPORTS PROFESSIONAL SERIES BATTERY
THEY ARE ALL THE SAME VERSION OF DEKA'S FACTORY ACTIVATED AGM ETX30L 400CCA BIKE BATTERY THAT ARE MFG'D FOR ALL THOSE COMPANIES BY 1 BATTERY MFG WHICH IS " EASTERNPENN / DEKA " LOCATED IN USA / PA.
Scott
* AUTOZONE
* PEP-BOYS
* BIG CRANK
* NAPA LEGEND
