Fuel Moto 2010 Ultra Limited Cam testing Dyno Info
Old 01-15-2010, 11:55 AM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
Received 4,104 Likes on 1,339 Posts
Default Fuel Moto 2010 Ultra Limited Cam testing Dyno Info
Here are some dyno test results from a cam install we just did on a 2010 Harley Ultra Limited 103". We installed the Wood's TW6-6 cams on this bike which already had our Jackpot 2/1/2 headpipe, Fuel Moto Stage 1 air cleaner and Dynojet PC-V and gave the bike a full dyno tune. The 103" bike responds very well to these cams with very good Hp/Tq increases. Throttle response is noticeably increased as well. These cams provide a very broad power curve, this combination makes over 100ft lbs of torque from 2650-5000 RPM! with stock compression and it makes power right to 6000 RPM. Overall this overall combination makes 30+ more Hp and +19 more Tq over stock, engine response is hugely improved and the bike runs substantially cooler.
Dyno Chart with Wood TW6-6 cams, Jackpot 2/1/2 head pipe, Jackpot Dyno Tuned mufflers, Fuel Moto Stage 1 air cleaner and Dynojet PC-V
Dyno Chart comparing the stock cams to the Wood TW6-6
Dyno Chart comparing the completely stock bike to the addition of Wood TW6-6 cams, Jackpot 2/1/2 head pipe, Jackpot Dyno Tuned mufflers, Fuel Moto Stage 1 air cleaner and Dynojet PC-V
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old 01-15-2010, 12:20 PM
lp's Avatar
lp
lp is online now
Received 2,716 Likes on 1,544 Posts
That is friggin amazing. Very nice numbers. I hope we can get similar numbers from your new 2-1. I already have the PowerTube and A/C. Just need the 103, TW6-6, and a PC-V...
Nice work Jamie.
lp
Old 01-15-2010, 12:46 PM
iclick's Avatar
iclick
iclick is offline
Looks good. It may not be possible with TBW, but I would like to see what's going on below 2300 RPM's in the TQ chart. As good as the 6-6's look, the stock cams performed respectfully with the other mods made.
Old 01-15-2010, 12:56 PM
fripple's Avatar
fripple
fripple is offline
What compression ratio is the stock 2010 103" Ultra?
Old 01-15-2010, 01:37 PM
fuelmoto's Avatar
fuelmoto
fuelmoto is offline
Platinum Sponsor
The Motor Company specs list the compression is 9.7:1. If you wanted to go a step further this motor would certainly benefit from some additional compression
Old 01-15-2010, 07:56 PM
RDM's Avatar
RDM
RDM is offline
Those are some nice looking numbers.
Old 01-17-2010, 06:28 PM
phattey's Avatar
phattey
phattey is offline
What's the stock cam in the limited..? Is it a 255..?
Old 01-17-2010, 06:36 PM
B-1B_Guy's Avatar
B-1B_Guy
B-1B_Guy is offline
Great work Jamie. I can't wait to get the TW-7's in my bike. If my heads were stock I'd definately go w/ the TW6-6's and your map.
Old 01-17-2010, 06:40 PM
Mike's Avatar
Mike
Mike is offline
I don't know why this rumor persists. No, the stock cam is the same one used in the 96" motors. The 255 is a stage II cam for the 103 motor. The 255 cam profile is unique, and builds torque very early, but is done sooner than most cams as well.
Old 01-17-2010, 06:53 PM
phattey's Avatar
phattey
phattey is offline
easy big fella...wasn't trying to feed a rumor...I was asking 'cause I didn't know.
BTW - I have the 255...but thanks for helping the fix the rumor mill...
Quick Reply: Fuel Moto 2010 Ultra Limited Cam testing Dyno Info
