FLHXI STREET GLIDE 1 1/4" REAR LOWERING KIT
Old 07-20-2006, 04:12 AM
CNC WHEEL GUY's Avatar
CNC WHEEL GUY
CNC WHEEL GUY is offline
Default FLHXI STREET GLIDE 1 1/4" REAR LOWERING KIT
Has anyone used this setup or one like this before?
See link:
http://cgi.ebay.com/ebaymotors/ws/eB...romZR40QQfviZ1
Any likes/ dislikes?
Old 07-20-2006, 04:17 AM
dgator66's Avatar
dgator66
dgator66 is offline
Default RE: FLHXI STREET GLIDE 1 1/4" REAR LOWERING KIT
Nope, but it would be interesting to find out. These things are pretty low in the back already.
Old 07-20-2006, 12:45 PM
DI75's Avatar
DI75
DI75 is offline
Any idea how it hooks up???
Old 07-20-2006, 01:18 PM
manowar's Avatar
manowar
manowar is offline
i have seen them they bolt on really easy, i was at my bike shop yesturday and the mechanic was saying that those kits put your shock at a differnt angle which is bad for the shock i do know alot of people use them but my guy said the right way is to go with a new set of shocks which is 500.00 by the way. if you do use them let me know what you think
Old 07-20-2006, 01:22 PM
DI75's Avatar
DI75
DI75 is offline
yeah but shocks only lower u one half inch!!
Old 07-20-2006, 01:51 PM
BB06FLHX's Avatar
BB06FLHX
BB06FLHX is offline
This kit is a piece of cake to install. Took me 30 minutes and that included looking for the right size tools. Can't give a ride impression cuz bike isn't reassembled yet.
Old 07-20-2006, 01:52 PM
BB06FLHX's Avatar
BB06FLHX
BB06FLHX is offline
BTW- The kit I used was the RUB kit but looks exactly the same.
Old 07-20-2006, 04:10 PM
Inforit's Avatar
Inforit
Inforit is offline
I have the solow lowering kit that I installed over the winter. As of now the bike sits about an inch lower than my father in laws stock SG and its noticeable. I took a trip to NC and did alot of twisties and had no problem with the clearance on the turns. So if you decide to do the 11/4 inch drop on street glide that will bring to about 11.25 inches where my bike is at 11.75 inches
Old 07-20-2006, 04:12 PM
manowar's Avatar
manowar
manowar is offline
inforit do you ever ride 2 up? and if so any info on the ride like that would be appreciated
Old 07-20-2006, 10:55 PM
Inforit's Avatar
Inforit
Inforit is offline
I rarely do ride 2 up becuase my wife rides her own bike, but if my wife does, then I throw the tourpak on as well. I make sure I have enough air in the shocks (about 20 to 25 lbs) and I do not get any buttoming out at all and the ride feels the same as solo riding. I also recently went on NC road trip with the tour pak loaded with clothes for me and my wife for two weeks figuring probably over 100 lbs in total weight including the weight of the tour pak and had not problem as far as buttoming out or riding the twisty roads. It will buttom out two up if you do not have the right air pressure, but that would happen to stock shocks as well if you run them too soft. But I do not know how it would be on the SG, due to the shock being shorter than stock RK shock to begin with and you will put you half inch lower than mine.
Hope that helps.
Quick Reply: FLHXI STREET GLIDE 1 1/4" REAR LOWERING KIT
