cracked tour pack trunk !!!
I bought a used trunk to put on my streetglide when I travel, the problem is: The trunk's corner has a crack in it...a bad crack and I was told that a fiberglass kit wont work becouse the trunk is made of plastic glass? I was wondering what would be best to use?....apoxy jb weld...bondo?
Try Plast-aid, Google it and call their office and ask them if it will work. VERY nice small business!! I talked to the owner/inventer!! They can ship direct.I used it to fix a leak in a hot tub and i got to say the stuff is incredible!!!! It is a powder that you mix with a liquid and you can make it paste like (Peanut butter)and form it.Takes about 10 minutes to fully set up,but once it sets it is good to go!! It can be colored also!!It is not a patch but bonds with material.It can be sanded!! Don't know about paint though? If you go this route PLEASE P.M. me and give me results!!
I am in no way affiliated with this product just found it to be great stuff!!!!.....
Ive repaired bags and fairings with regular body filler after reinforcing the back side. Body filler will work to fill the crack.. You might try abs plastic cement and a patch on the back side of the crack or you could use fiberglass cloth and resin and it will hold if its not too badly broke but I have found the abs glue and an abs patchworks best . Im not really sure what the H/D bags are made of but it sure looks like ABS .
Repairs for inside a trunk or saddle bag can be made, this is one I used and it worked.
The crack should be stop-drilled before the crack is patched. Stop-drilling will help prevent the crack from spreading further after repairs and relieves the stress.
To stop-drill a crack, drill a small 1/8 inch hole directly in front of the cracks path,, about 1/8th inch ahead of the cracks path,, the crack will find this hole and relieve the stress and stop the crack in its tracks. Sand the inside of the repair area and wipe down with a rag dipped in lacquer thinner and let dry.
Lay down a cover of adhesive (2-part) spread the adhesive wider than the crack edges by about 2 inches then cover the adhesive with a thin plastic plate,(plastic milk jug), then cover with another layer of adhesive and smooth out the edges.
Working with the adhesive quickly will give you the best bond, (don't mix a hot batch) allow time for it to harden in a warm room and you should be ready to finish if needed inside and outside. hope this helps you.
R.
R.
