Reconnect 02 sensors?
2010 RK
installed 551 cams and had it dynoed. Mileage went to crap. Since then I installed a S&S 106 kit with 585 easy start cams and a downloaded map.Only concern is gas mileage as bike runs better than I expected.So I'm wondering if I should connect the 02 sensors to increase mileage and if there will be a problem not having it re-dynoed.
mileage is upper 30's but never 40's even when just tickling the throttle
If this is what is to be expected , I'll live with it. Thanks in advance. I learn a lot on this site..
Using a power commander. I didn't want to use the same guy that did the initial dyno as I felt he just added lots of fuel to the tune and he stated too many complain on the fuel consumption and he tunes for performance. I feel there can be a compromise as it is after all a street bike not a drag bike.. I plan on going to Doc Harley in CT. in the spring and getting it done.
I was just curious if I connected the 02 sensors if it would perform allright.
Thanks for the reply
Iron lHorse
10-22-2013 06:02 PM
