ATF in Primary???
Old 01-23-2010, 05:56 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Default ATF in Primary???
I know some of you guys are running ATF in your primary.
Are there any disadvantages to this?
EXACTLY, what are you running?
Dexron Mercron...what???
Old 01-23-2010, 06:00 PM
Pacodelahoya's Avatar
Pacodelahoya
Pacodelahoya is offline
I run B and M Trick Shift. 8000 miles and no probs.
Old 01-23-2010, 06:18 PM
kurtlange's Avatar
kurtlange
kurtlange is offline
dexron 2, no problemo...
Old 01-23-2010, 06:20 PM
Sancho's Avatar
Sancho
Sancho is offline
Currently using B&M trick shift. I saw some Dexron III at Dollar General for $2.49/qt.
I just bought 10 ltrs Bardahl primary lube from Dennis Kirk for $1.50/ltr. 1 ltr=33.842 oz.
Old 01-23-2010, 06:33 PM
BadPiggy's Avatar
BadPiggy
BadPiggy is offline
Those using B&M...what is your change interval?
Old 01-23-2010, 06:38 PM
1mrbill's Avatar
1mrbill
1mrbill is offline
'04 Road King Custom, Mobil 1 Synthetic ATF in the primary, no issues. Change once a year when I change the transmission oil, which is Mobil 1 Synthetic gear lube.
Old 01-23-2010, 06:45 PM
cap5369's Avatar
cap5369
cap5369 is offline
I use Dexron III and change every 3 oil changes not sure if that is good or bad but I like to keep it clean, that is just me. Ride safe.
Old 01-23-2010, 06:59 PM
'05Train's Avatar
'05Train
'05Train is offline
Amsoil Supershift. Change it every 10k, same as the transmission (which has Amsoil Severe Gear 75W-90). Shifts are smooth and positive, neutral's easier to find, and I've seen no downsides.
Old 01-23-2010, 07:18 PM
Dalton's Avatar
Dalton
Dalton is offline
Have run Dexron II/III for the last 45000 miles without issue. The B&M trickshift and the Mercon makes it just a tad harder to find and maintain the friction zone for low speed manuevering.
I change the primary oil at 10,000 miles just cause it has clutch dust in it, but could go longer.
Old 01-23-2010, 07:22 PM
TexasBowhunter's Avatar
TexasBowhunter
TexasBowhunter is offline
Same here...
Quick Reply: ATF in Primary???
