Yep, did the upgrade to mine a few months ago. Couldn't be happier. I also added a baisley spring and replaced the cam sprockets/chains. Seems a lot of my valve train noise was due to sloppy cam chains.
I put one in my 02 FLHPi when i replaced the cams last year. I'm definately happy with it.
I am thinking of doing the same with my 03 Dyna before too long. I see you have HQ0034 cams. How do you find them? That is a possible replacement for my stock cams!
I just had it installed this past weekend. I brought the scoot up to dawgs new man cave so that he could get to use his new table lift. He was all excited. I had to bring up my own heater. I sacked out on the couch he has in his man cave and made my self comfortable. Time will tell on this upgrade, but I am glad I did it.
If I'm not mistaken, the SE kit still uses the inner silent chain, correct? Where as the others replace both chains with rollers? Or did you guys not do the conversion, and just change tensioners and cam plates?
