Cam Installation Kit
Old 02-02-2010, 12:37 PM
gobblerhuntr's Avatar
gobblerhuntr
gobblerhuntr is offline
Default Cam Installation Kit
I am putting cams in my 06 ultra, question is Does the cam installation kit from HD have all I need in the form of gaskets and bearings and such?
Old 02-02-2010, 12:45 PM
mtclassic's Avatar
mtclassic
mtclassic is offline
yes unless you are going gear drive.
Old 02-02-2010, 12:58 PM
dawg's Avatar
dawg
dawg is offline
Received 2,961 Likes on 1,714 Posts
Cam service gasket kit 17045-99C will have everything you need. I suggest buying the SE inner cam bearings though or B148's elsewhere (SE are the B148's). You cutting rods or reusing? If going through the rockers and reusing, buy an air cleaner gasket as that is not in the kit.
Old 02-02-2010, 12:59 PM
gobblerhuntr
no gear drive here, wondering about the bearings that come with the kit and who makes em.
Old 02-02-2010, 01:13 PM
dawg's Avatar
dawg
dawg is offline
The bearings in the kit are INA bearings. If you get the SE inner bearings they are Torrington/Timken
Old 02-02-2010, 01:16 PM
Modee1245's Avatar
Modee1245
Modee1245 is offline
This may sound dumb, however, what is a cam and what is it for...
Old 02-02-2010, 01:17 PM
Anezangl's Avatar
Anezangl
Anezangl is offline
Cool
Gobblerhuntr, I just completed a build. Used Harley S/E parts. 95" big bore, updated cam plate w/ hyd. tensioner's, new cams, new oil pump, etc... on and on. The inner cam bearings did not come with the kit, had to buy them local, Torrington B-148's for mine. I believe the outer bearings with the kit were INA. Anyway, point is that all the different kits required for my build were "supposed" to include all the gaskets and o-rings and pieces parts but unfortunately not one of the kits was complete. That was the most aggravating part of the build, every time I opened a kit I had to run out to one of the three Harley dealers around me and purchase the missing part. The gasket for the cam chest cover was there but had been folded so that it had a crease in it and I was afraid to install it. If you cut your rods and purchase S/E adjustable's use caution when identifying the TPI and jam nut revolutions when preloading your lifters. As I found out the hard way, some of the packages call out an incorrect TPI which can put a real hurting on your heads. :-(
Old 02-02-2010, 01:24 PM
Anezangl's Avatar
Anezangl
Anezangl is offline
Talking
Modee1245, your playing right? Short for camshaft. In short its what determines how well your scooter inhales and exhales.
Old 02-02-2010, 03:08 PM
gobblerhuntr
Wasn't planning on cutting rods, but think I will get the 148s and you say an air cleaner gasket also eh?
Old 02-02-2010, 03:46 PM
dawg's Avatar
dawg
dawg is offline
Just did soos' bike this past weekend and I forgot the A/C gasket and removed it to pull off the pushrod covers.
Quick Reply: Cam Installation Kit
