Battery life in the Key Fob
Old 02-11-2010, 09:33 PM
Buzzsaw's Avatar
Buzzsaw
Buzzsaw is offline
Default Battery life in the Key Fob
Anyone know the average life of the battery in the newer style key fobs. Was in the Garage tonight and after I finished re-installing the ignition switch went to make sure the bike would start. The alarm started to flash, got the other Fob and still would not start...The only way to start the bike was to bypass the security with the turn signal combination.
Just seems strange that both Fobs would die at the exact same time. Will try a new battery tomorrow.
Wondering if anyone else has had this, or is there the possibility that the system somehow got reset and does not recognize the Fob's anymore?
Only work done recently was Cruise installed by the Dealer, and I just put in a homemade Garage door setup in the lower fairing cap and I unplugged the wires in the lower cap to get it off. Never had an issue before with that.
Old 02-11-2010, 09:44 PM
bdp's Avatar
bdp
bdp is offline
Bought my 08 the end of Mar 08 and one fob died in Dec 08. Changed batteries in both and have been good for over a year now.
Old 02-11-2010, 09:45 PM
dabluesguy's Avatar
dabluesguy
dabluesguy is offline
Around two years.
Old 02-11-2010, 10:06 PM
RKKY's Avatar
RKKY
RKKY is offline
Around two years.
Been my experience as well.
Old 02-11-2010, 11:12 PM
txfxstrider's Avatar
txfxstrider
txfxstrider is offline
Had mine going on three years and still going strong. I think the book says to replace them every year. I doubt that both would give out at the same time.
I think you did something when working on the bike. Try pulling the main fuse and re-inserting it.
Old 02-11-2010, 11:21 PM
acftdr's Avatar
acftdr
acftdr is offline
Same here....Pretty much 2 years. Check the battery voltage. It's a 3v battery to start, so if it's much lower than that, replace it. CR2032 battery if I remember right.
Old 02-11-2010, 11:23 PM
bord3r's Avatar
bord3r
bord3r is offline
mine died today i was 85 miles from anything and dont laugh at me but i didnt know how to bypass it but a guy pulled up on a bmw he is a harley tech and he showed me how... my exp the fob battery laster 11 months
Old 02-12-2010, 12:37 AM
rhenicke's Avatar
rhenicke
rhenicke is offline
I'm glad this came up the fob I use all time didn't work after sitting did the turn sig thing ,started working ,but other doesn't , I'll check batteries. Dealer told me you only have like 10 seconds or memory loss, is this B S also ?
Old 02-12-2010, 06:07 AM
Buzzsaw's Avatar
Buzzsaw
Buzzsaw is offline
I am guessing it is the batteries, Bike is an 07 and I haven't had to change them yet. With the wx the bike had been sitting on the Battery tender and the roads have not been good enough to ride.
If the Batteries don't work, guess I will have to have them reprogrammed.
Old 02-12-2010, 07:29 AM
honestbob's Avatar
honestbob
honestbob is offline
I changed both mine at two years. They were both working , but they are cheap and easy to change. Battery # 2032
Quick Reply: Battery life in the Key Fob
