Installed SE-255 and SEPST today...
After much debate and research, I installed the SE-255 cams that my buddy gave me in my 08 Road Glide today...WOW! I read all the different cam debates and had told myself I would use the TR-525C, but my budget didn't allow me to go that route. I already had the 255s, so I took a shot with this cam figuring that I'll do a BB kit somewhere down the line. The guys I ride with all like to twist the throttle, so I just needed a little bit more umph...I went with the SE Pro Super Tuner that I got off eBay for $250...worked like a charm, no issues...had the bike dyno'd and it got 82HP and 100TQ! The service technician was suprised it put up those numbers since I am using stock head pipes and Vance & Hines Monster Ovals slip ons. He said when I go to the D&D 2:1 Fat Cats, both numbers should get a good bump...at any rate, I'm extremely happy with this for the moment until I get some more loot! I know you can't ride a dyno sheet, but it's a good reference point...the ride home was a nice tease, but I should be able to put it through its paces tomorrow!
I also have the SE255 and am ready to swap it out.Did you install new lifters, if so which ones, if not why?. What pushrods did you go to? I'm also thinnking of going to the FuelMoto Power Headers, they say close to the same power as the 2-1 exaust, and IMHO look better. thanks for any info.
Got an early start this morning and was able to get a nice solid ride in today. It's sunny and 75 in Los Angeles today (all week actually...sorry cold climates) so it was a great ride. I can definitely feel a difference in the butt dyno...much more throttle response and the power is truly right in the sweet spot for this heavy bikes just like UltraKlassic said! I was able to roll-on and pass any car I wanted/needed to and the bike really ran well--I think MOCO should send them from the factory like this! I can already tell that I will definitely want more, but I am happy I threw the 255s in since I already had them. I was riding by myself so I cannot tell if I will still get dusted by my friends, though, I highly doubt it. Also, I think my gas mileage went down considerably (was getting about 40-42 mpg), but I just filled up and will check later; I was kinda twisting the throttle a little more. I will ride in to my office in tomorrow and will get on it some more! Ride safe!
I've wondered about this, too. I suppose since the 255's go in the CVO bikes they need to keep the performance level separated enough from the lower-class bikes like ours to make the high price justifiable. If they can meet EPA certification with the CVO's it would seem certain they could also do so with the 255's in a stock TC96.
I definitely won't be needing more, as I rarely need to give this bike more than half-throttle for anything, and even a spirited roll-on can be accomplished with <WOT. On a trip last May to the Smokies I was amazed at how easily the engine negotiated the hills with minimal downshifting, even when loaded down like it was. It was a real pleasure to ride.
Crummy mileage is a normal side-effect from a performance upgrade like that, at least at first until the newness of the extra pep wears off a bit and your throttle hand relaxes a bit, although for me hasn't done so completely after 11 months. You might ask the tuner if he can lean the cruise range a bit, like to 14.2:1, the lowest (richest) you can go with the stock O2 sensors in closed-loop mode, or even leaner. That'll help mileage while at part-throttle.
You sound like a happy camper like me. I rode mine today and like every time I ride it I marveled at how good it feels now. Great uprade, IMO, especially if you DIY.
The '09 and '10 bikes will just feel even peppier than my '07 with the higher gearing does now. I can't see a downside to this, although these cams do give a slightly "abrupt" feel at slow speeds in first gear. This is from the higher CCP that translates into noticeably better throttle-response. I noticed this the first day I rode after the cam job, but quickly got accustomed to it, and would never consider it a point of complaint. Let's call it a "quaint little side-effect." With lower gearing this would likely be enhanced, but I am just speculating, and I can't say if anyone would find it a negative since I've never heard anyone complain about it. Can anyone with one of these newer bikes comment on this?
