Relocate Tourpack antenna to Fairing?
I am converting my Electra Glide Classic Tourpack to a detachable version, so I can run a detachable backrest/luggage rack when the mood strikes me.
The dealer plans to snip off most of the antenna and relocate the antenna to inside the front fairing (I am leaving enough antenna on the pack to put a flag on). The dealer tells me that this works fine and does not affect the quality of the radio reception.
Has anyone installed the tourpack antenna relocation kit where the antenna was moved to inside the fairing? Did it affect your radio reception?
Some quick feedback would be appreciated.
RE: Relocate Tourpack antenna to Fairing?
ORIGINAL: Easyglide
I'm no electrical engineer by any stretch of a vivid imagination and some may say I'm talking out my a$$, and I may very well be. I've been called worse. But any hidden antenna that I have seen has received a power boost, not just cutting down a regular antenna. My opinion is that it wouldn't work too well. Take it for what it's worth.
Russ
To be honest, cutting the antenna off and relocating it to the fairing is an idea I hadn't heard of before. There are several on this forum who have applied the same concept except the original antenna wasn't used. Instead they use a small amplified antenna which looks like an XM/Sirius receiver (signal booster) or 24" (approx.) of wire antenna taped to the inside of the fairing. The only thing I did to the antenna on my Ultra was cut it down a bit. When I removed my Tourpack (quick release) I just went without radio and listened to CD's instead. My neighbor who also rides an Ultra, relocated his antenna with the kit available through HD which mounts between the rear fender and the saddlebag. Looks nice and is out of the way.
A lot of folks rave about the Tune Trapper hidden antenna .. Click Here to check it out. Just another option.
I picked up a Metra powered antenna from AutoZone for $20. I mounted it inside the fairing and it works great. I got rid of the CB antenna since I never use it.
You will loose a bit of reception when you get rid of the tall whips...........but it's well worth it for the looks factor.
Steve
Steve
