Roadglide inner fairing trim
Old 02-20-2010, 10:30 PM
creep1's Avatar
creep1
creep1 is offline
Default Roadglide inner fairing trim
Ok i wanna know if im the only one having this issue with the three inner fairing trim peices. They all seem to leek glue i guess from shifting or heat. Maybe its not glue but a tacky film to help adhere the trim to the inner fairing, but either way mine are making a mess. The first time i had my outer fairing off i replaced all 3 trim peices, but now im back to square one with this mess.
Old 02-21-2010, 07:10 AM
creep1's Avatar
creep1
creep1 is offline
just checked one peice of trim is starting to wrinkle. now im gonna have to change again
Old 02-21-2010, 08:31 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
The adhesive used does not like heat.I had the same issue and had it reglued under warranty a couple times,the same thing happend.
I ended up removing all the adhesive and reglued with Loctite super glue.This adhesive will not melt like the other crap the factory and dealer used.
Old 02-21-2010, 08:37 AM
hawg50's Avatar
hawg50
hawg50 is offline
get the rubber seals for a street glide,they work a lot better than the road glide rubber.i have an 06 ultra that i painted the inner fairing and used the street glide rubber on and its been over a year without any problem.i have a road glide that im presently using the street glide rubber seal on as soon as i get the inner painted.
Old 02-21-2010, 09:23 AM
frydaddy96's Avatar
frydaddy96
frydaddy96 is offline
Go to an automotive store (Autozone, Pepboys, etc) and get a roll of door edge trim. Has its own adhesive, replaced mine this winter so can't say how it will do in the heat. Do a search for fairing trim, there are others who have done it for longer and did not have issues with heat.
Old 02-21-2010, 01:42 PM
DougM's Avatar
DougM
DougM is offline
i had the same problem. Took the stock trim off and cleaned inside the trim and the fairing with Goo Gone. Then I used silicone caulk (the small tube that you squeeze with your hand vs. a caulk gun). It has seemed to stay put very well. I thought about the super glue method but didn't want it to be as permanent in case I ever have the inner fairing painted.
Old 02-21-2010, 03:41 PM
ucommbxny's Avatar
ucommbxny
ucommbxny is offline
08 Road Glide, thats one of the issues on my warranty to do list, seems like a common problem
phillyrube
06-10-2018 10:43 AM
KDUBYA
Powdercoat & Paint
09-13-2014 09:03 AM
8828alex
03-25-2014 06:43 PM
ezglider
03-31-2010 08:51 PM
gliderman
03-03-2008 11:06 AM
Quick Reply: Roadglide inner fairing trim
