Removing the Chrome Inner Fairing Trim Kit
Old 03-04-2010, 07:09 PM
shortride's Avatar
shortride
shortride is offline
Default Removing the Radio and Gauge Face Trim
I've got the Radio and Gauge Face Trim (74612-06) on my '09 Ultra Classic and I don't particularly like the chrome bezel around the radio and the 2 bottom gauges. Has anyone ever removed one of these without damaging the inner fairing. I'm also not sure what hold it on. Maybe double back tape?
Old 03-04-2010, 07:36 PM
HDV-GLIDE's Avatar
HDV-GLIDE
HDV-GLIDE is offline
Yep, it should be double faced tape....It should pry off and then use something like WD-40 to soften the tape and residue. Get it soft enough and use your fingernails to scrape it off. Might take a while but at least you will not scratch the fairing using a sharp instrument. Some rubbing alcohol when your done to remove the WD-40 and then some "Armour All" type of product on the whole inner fairing.
Old 03-04-2010, 08:44 PM
imskier2's Avatar
imskier2
imskier2 is offline
You should try to get some wd-40 on there first to soften the double side tape, if you don't you will flex the metal and the chrome will flake. Don't ask me how I know. But if you are just going to throw away the chrome anyway don't worry.
Old 03-04-2010, 09:12 PM
cdestuck's Avatar
cdestuck
cdestuck is offline
Get out the hair dryer and warm it up first. Ya gotta know.......always gets off better when hot!!
Old 03-04-2010, 09:14 PM
Navy Mustang's Avatar
Navy Mustang
Navy Mustang is offline
I for one never could understand why anyone would put that fugly accessory on their inner fairing. I guess to each his own. I'm sure with patience you'll get it all off. Good luck.
Old 03-04-2010, 09:22 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
wcsj55@yahoo.com is offline
Heat gun or hair dryer,don't get it to hot pull off slowly,clean up with WD40 !!
Old 03-05-2010, 01:04 PM
shortride's Avatar
shortride
Got it done. It came off fairly easily with a heat gun. There was no double-back tape residue to clean off.
sloans4x4
Touring Parts
02-27-2015 08:40 AM
jefla
02-18-2012 09:02 PM
hdman6
11-13-2011 10:14 PM
RCNFVR
09-12-2009 01:44 PM
SecondChance!!
04-03-2009 07:16 AM
Quick Reply: Removing the Chrome Inner Fairing Trim Kit
