20003 RoadKIng Clutch Cable Lube
Old 03-09-2010, 07:00 AM
40 Knuck's Avatar
40 Knuck
40 Knuck is offline
Default 20003 RoadKIng Clutch Cable Lube
Would appreciate "helpful hints" and step by step - how best to lube my clutch cable - best lube product recommendations and "how to" as I have not done did this myself.
Thanks!
Old 03-09-2010, 07:10 AM
BoomerBob's Avatar
BoomerBob
BoomerBob is offline
Loosen cable at adjuster located at mid cable. Take circ clip holding pin in clutch lever off, remove pin, take cable off, and flow some cable lube into cable.
I happen to like Tri-flow for this application. It has Teflon in it which the plastic lined cables need and even if it isn't plastic lined it's still an excellent lube.
Old 03-09-2010, 07:35 AM
juscoop's Avatar
juscoop
juscoop is offline
I also use tri-flow man that stuff is great. I use it on my guns and fishing reels. I also use this cable oiler to help push the lube all the way through the cables. http://www.jpcycles.com/search/produ...ement_search=1
Old 03-09-2010, 07:58 AM
dawg's Avatar
dawg
dawg is offline
Received 2,955 Likes on 1,711 Posts
Here's another way to do it.
Old 03-09-2010, 08:04 AM
carpetride's Avatar
carpetride
carpetride is offline
I use a syringe and just stick the needle along side the cable up by the clutch handle. I use 3 in 1 oil.
c50plus
05-23-2016 08:52 AM
Weirbt
General Topics/Tech Tips
04-27-2014 07:46 AM
Whiskyjock
01-12-2014 10:50 AM
barb6663
07-04-2012 08:09 PM
srawden
04-03-2006 07:50 PM
Quick Reply: 20003 RoadKIng Clutch Cable Lube
